Author Topic: most broken equipment you run into?  (Read 9598 times)
Offline coppercone2Topic starter
« on: December 09, 2023, 07:07:29 pm »
What equipment do you think breaks the most?
IMO from what I have seen, its either scopes or power supplies. In terms of breaking without a bad user, its scopes IMO. Lots of broken supplies because of solenoids or batteries, but scopes just break.
In the repair equipment closets I seen, scopes seem common.
And they are usually treated better, since supplies are cheap compared to scopes.
Offline Zenith
Re: most broken equipment you run into?
« Reply #1 on: December 09, 2023, 07:56:22 pm »
Scopes don't just break, they can struggle on for years being useful to the owner with only one channel working, or the triggering not working properly, or some feature not working, etc. Back in the day they were expensive prized possessions, and wouldn't be lightly thrown away, even if they didn't work at all. There were commercial repair services, but they were quite expensive. I'd say that power supplies were more likely to be thrown away.
Scopes are almost certainly inherently less reliable than power supplies because of complexity, many switches and controls which can cause problems and very high voltage circuitry.
I haven't taken a count, but I have the impression I see more second hand/junk scopes than bench power supplies. Maybe it's just that I notice the scopes.
I don't see many of those little analogue multimeters around that were popular in the 60s and 70s. They were fairly easy to damage and most people would prefer a DVM. There'd be much less reluctance to throw one away.
« Reply #2 on: December 09, 2023, 08:03:42 pm »
i still see it with new scopes though ;D like keysight
Offline MadTux
« Reply #3 on: December 09, 2023, 08:05:13 pm »
Well, with oldish Tek scopes, unless tube or a few custom parts break, it's all user fixable, even tube and ASICs can be salvaged from part units.
Nowadays, break any custom chip in a scope and it's usually bricked. Unless you have BGA rework station and a unit for scrap to salvage parts, you're screwed.
Then shitloads of programmed parts, too. Where you usually can't get firmware for.
Power supplies, until maybe 2000s, it's usually easy fix, unless VFD display or something.
It's even fricking welders, nowadays. Imagine that thing for 20years in metal dusty workshop, electronics fry for some reason and you have the fun of fixing it.
https://www.mikrocontroller.net/topic/557851
« Last Edit: December 09, 2023, 08:07:50 pm by MadTux »
Offline Zenith
« Reply #4 on: December 09, 2023, 08:26:52 pm »
Low end amateur grade inverter stick welders are a likely contender. They are built on the cheap, they are kept in damp sheds and often showered with metal particles. No conformal coating or channeling to direct the cooling air only to the heatsinks. They are very clearly not intended to be repaired and there's very often no service information at all.
El cheapo SPMSs cause a lot of problems.
Offline joeqsmith
« Reply #5 on: December 09, 2023, 08:41:24 pm »
Maybe a better question is what have you seen people do the most often that damages equipment?
Offline MadTux
« Reply #6 on: December 09, 2023, 08:43:14 pm »
Chinesium and cheap Fronius stick welders are horrible throwaway items, from what I've heard.
That Rehm one, isn't exactly a cheapo, though ;-D
https://www.weldingtool.eu/rehm-wig-schweissgeraet-invertig-pro-compact-280-ac-dc-digital-ohne-zubehoer.html
Miss the old days, where everything was sectioned onto plugin cards and you get a 500page service manual, with schematics.
« Reply #7 on: December 09, 2023, 08:59:18 pm »
like use it once in a while for <10V signals when its sitting in a closet with cover on most of the time
Offline Kim Christensen
« Reply #8 on: December 09, 2023, 09:07:15 pm »
Probably the worst are those instruments that have a sensitive input. Like a milliwatt RF power meter or RF signal generators that people accidentally connect to a 100W+ transmitter.
Another one that was really bad was the Fluke 725 Multifunction Process Calibrator which looks a lot like a regular Fluke DVM. The electricians would confuse those with a DVM and blow them up all the time by measuring mains voltages with them.
Offline MadTux
« Reply #9 on: December 09, 2023, 09:28:02 pm »
Those Fluke calibrators are a joke anyhow, $4000 each and not even 1000V tolerant input.
Not like those are for lab use only, 3phase 400VAC all around, where these things mostly live.
Fluke probably gave them banana jacks on purpose, each time some unsuspecting noob connects more than 30V to it, good repair/replacement money for them. ;-D
Offline Zenith
« Reply #10 on: December 09, 2023, 11:12:49 pm »
It's the way the world has changed.  In the days of valves (toobz) repairing TVs was a considerable industry. These days TVs last for years and when they fail, I doubt they can be repaired. I was talking to the people at the local dump about the TVs and monitors they take. They said they almost all work. Most people get rid of them because they are too old.
The following users thanked this post: AlcidePiR2
Offline antenna
« Reply #11 on: December 09, 2023, 11:17:17 pm »
5kΩ pots
Offline Wallace Gasiewicz
« Reply #12 on: December 09, 2023, 11:32:04 pm »
I believe Coppercone is correct, its either PS or Scopes. but these are the most common equipment anyway.I used to pick up scopes and PS at hamfests and fix them, If i got a nice one I would keep it, otherwise sell for my TE fund.
But now, with the advent of new DSOs being so nice and cheap, it does not pay to refurbish old scopes.  In my part of the country at least, some really nice old tek scopes are going for less than $100.  Would have purchased them just a few years ago.
On the broken old scopes, it was usually something like a burned input FET and a quick fix. You could pick up a quick couple hundred bucks this way. Not so with the new DSOs.
The PS are becoming more and more switching, so they are harder to repair, probably not worth it.   I still try to pick up Big Linear PS when I can.  Lots of radio operators are always looking for them. Pretty easy to fix if the transformer is not burned. Does not seem to be much of a market for Lab PS though.
I picked a uninterruptible NEG 48 volt PS off the ground at a hamfest after the vendor left it. I fixed the thing and now both PS work.  If anyone wants to pick it up for cheap, I am in Indianapolis. This is a telephone company PS.
« Reply #13 on: December 09, 2023, 11:48:55 pm »
but what I am saying is that I see DSO failing that are not used much and new ! like tektronix etc. anything from front panel buttons to channels going off. that stuff has repair tag on it ALOT
Offline floobydust
« Reply #14 on: December 10, 2023, 12:51:41 am »
#1 busted test equipment I see at work is bench power supplies. I went through over 6 repairing them and adding protection diodes if they were missing.
No engineering budget dollars to buy new ones, so I simply fixed them while jr. engineers were bamboozled I would take them apart and knew what I was doing in there.
For other tagged test equipment, it can be people not knowing how to use it and thinking the scope is defective when it's not showing what they want or expect.
I was doing probe comp and again the jr. engineers were fascinated what I was doing turning a trimcap in the probe so square waves looked proper.
Offline xrunner
  • hp>Agilent>Keysight>???
« Reply #15 on: December 10, 2023, 01:07:36 am »
Yep power supplies and power testing equipment. I sometimes help out a local company that makes a few products because I know the owner. I just repaired a Topward TPS-4000 for him which had a broken power switch (the metal switch stem was snapped off). He also has a Agilent 6050A electronic load which has a suspiciously loose AC input connector. Might be dangerous I don't know yet. But they are both heavy and people have trouble moving them around. So I guess my answer to the question is - anything that is very heavy is some of the most broken equipment out there.
Offline chickenHeadKnob
« Reply #16 on: December 10, 2023, 08:52:44 am »
Probably not what coppercone was looking for or expecting:
anything from my father's age which had bakelite cases, like simpson meters. It seemed everything we had in bakelite had a corner chipped off. They still functioned ok, so not really in the totally fuxored category. Out of curiosity I googled and found you can still buy Simpsons new! $1000+ canuck bucks at Mouser.ca. https://www.mouser.ca/c/test-measurement/multimeters-voltmeters/analog-multimeters/?m=Simpson What the hell? who is buying these?
I had a colleague that was expert in overloading function generators and blowing them out. Not sure if that qualifies either.
« Reply #17 on: December 10, 2023, 09:19:04 am »
I can totally see someone using an analog meter for doing regular shit. its like visible and you learn what the needle bounce could mean for regular circuits.
and if you are doing brain-dead measurements then just knowing the needle % is way easier then interpreting a number
alot of people can't stand number clocks even, let alone number meters, the digits are like imposing, the dial tells you like a percent of
LOL at what would happen if cars only had a # display
« Last Edit: December 10, 2023, 09:21:08 am by coppercone2 »
Offline factory
« Reply #18 on: December 10, 2023, 05:45:13 pm »
Ebay's reporting algorithm  :box:, it seems to reject every report I make for; search manipulation, brand name spamming and incorrect catagories.
« Reply #19 on: December 10, 2023, 06:30:35 pm »
Maybe someone who doesn't want to rewrite old test procedures. Sounds like something the military would do.
« Reply #20 on: December 10, 2023, 06:31:49 pm »
well do you wanna tell 18 year old "its just like driving a car" or electrical theory
Online abeyer
« Reply #21 on: December 10, 2023, 09:30:00 pm »
So the original question was just "equipment" but didn't really specify what qualifies, and people just jumped to test equipment... But in my opinion, everyone seems to be overlooking the likely far-and-away winner of cell phones here -- they're almost certainly the most broken given the combination of sheer quantity and being carried around in inhospitable environments on a daily basis.
Offline DaJMasta
    • medpants.com
« Reply #22 on: December 10, 2023, 10:50:06 pm »
I think you're seeing some bias just because scopes and power supplies are so prevalent, though there are a few others that are common and maybe don't feel like they fail as much.
But RF equipment has some kind of failure frequently, often due to misuse (easier to do, more risky conditions, more sensitive inputs/outputs, etc.), but also just to aging.  Amplifier stages often run hot and just by leaving it on for long enough, you see a good bit of older RF gear which just needs an amplifier somewhere in the chain replaced, but you'll see mechanical failures of attenuators and things too.  Then again, some of this may be the bias that fewer people are attempting to actually repair them.
As someone who's seen a lot of faults... I don't think there's a class of instrument that stands out as more likely to fail.  There are bad designs, commonly failing components or elements, and equipment/interfaces that are more likely to be abused, but on the whole things are much more similar in terms of non-user-error faults.
Offline factory
« Reply #23 on: December 10, 2023, 10:53:45 pm »
There are some cars that don't have an analog speedometer, the Citroen C4 being one example, thankfully only had that PoS for a day or two over 10 years ago.
Offline Paceguy
« Reply #24 on: December 10, 2023, 11:17:05 pm »
Lately, it's been much of the stuff that I purchase on ebay. Badly packaged by careless sellers
