Author Topic: Motherboard 5V rail issue  (Read 679 times)
Offline bogdan2014Topic starter
« on: April 07, 2020, 10:18:39 am »
We have this older computer at work that has a strange issue. When powered up, it doesn't POST or boot, but every LED that lights up "pulses" like the 5V rail was pulled into protection. I have checked it with a multimeter and indeed the voltage drops in cycles, but the other rails are absolutely fine. The power supply does not go into protection itself, it continues to power the rest of the computer (fans and hard drives work). Something probably pulls the rail but not enough to trigger the overcurrent protection. I have replaced the power supply and the same issue occurs.
I have eliminated almost everything that might cause an issue outside of the motherboard, even the RAM, I have also replaced some leaky caps. What can I possibly do to salvage it?
I would scrap it but it's the only one we have that works in that configuration.
Offline Rasz
    • My random blog.
Re: Motherboard 5V rail issue
« Reply #1 on: April 07, 2020, 11:52:02 am »
start with model of the board
remove everything out of the case and plug just the bare minimum
