The question is: Did this board "work" before recapping? I.e. boot up and crash? If it has been dead before, replacing the bad caps might not even help.
I have seen *many* boards with bad caps, usually they become instable over time (which could be as long as several years), eventually they become unusable, but still show signs of life.
However a leaking cap might very well destroy traces or leak below some IC, creating unnoticable corrosion and/or unwanted conductivity. Very hard to diagnose, and most likely not worth the effort to fix.
