My wife's trusty Dell e510 (about 10 years old) suddenly began having issues last week and then crapped out completely a couple of days ago. This is a machine we specced out and purchased in late 2005, and we went with higher end components and expandability. Consequently, this originally 1gb ram WinXP computer is now a 4gb, 1TB+ Win7Pro64 computer and runs that OS with excellent speed.
Well, at least until this week. Now it boots, but then errors out with video artifacts and then shuts down within a couple of minutes.
I booted Ubuntu on a USB drive to recover data and...ooh, look, video artifacts. Crap. I took it out of service and started checking. After verifying the power supply was putting out the expected voltages, I removed the memory and cards and did a visual inspection of the components. Hmm. Bulging and vented electrolytic capacitors. (See attached photos.)
I do not see any significant corrosion or damage to the board itself, the caps seem to have vented only at the top. Upon close inspection, there are only three bulged cans, two of which have vented. All three are identical, 820 microfarad. I have not fully inventoried the board, but there are at least some other identical caps which have not vented.
So, I'm going to try my hand at replacing these. I have nothing to lose, and I hate to replace a computer that is still completely meeting our needs.
It seems I have several options.
1. Complete re-cap. All failed and nominal caps replaced. Pros: can replace all with good caps. Cons: nearly 50 caps to replace, which is about 15x the chance of screwing something up.
2. Partial re-cap #1: Replace all failed caps and caps that are identical to the failed cap. Pros: Decent chance of ferreting out caps that are 'about' to fail. Cons: Most old caps left in place.
3. Partial re-cap #2: Replace all failed caps. Pros: Probably fixes board, less expensive, less chance of screwing something up. Cons: May leave short-time-to-fail caps in place.
So...thoughts? Should I consider a limited distilled water rinse to remove any aerosolized electrolyte that settled on the boards? Do I finally need to bite the bullet and buy the WES(D)-51, or can the 15w pencil iron I have used for nearly everything I've ever put together or repaired (from radios to Arduino shields) handle the task with a reasonably delicate touch?
