Author Topic: What is the white glue/goo/rubber that fixates high-rise capacitors called  (Read 4431 times)
Offline eplpwrTopic starter
  • Junior VoltNut
Hi!
I'm in the process of replacing a number of capacitors on a PSU board (for a 2014 vintage Samsung 4K monitor). Many of the capacitors are fastened to the PCB with some kind of white stuff that is somewhat rubber-like - it is obvious that the stuff is there to steady the capacitors mechanically. It can easily be cut with a knife or removed piecemeal with a cutter, especially since my capacitor removal is desctructive.
After finished cap replacement, I would like to add similar "goo-stuff" to make the capacitor fixing as robust as before, but I am totally unaware what "the white stuff" is called. Does anybody know what the stuff is, and also if there is a special process or tools needed when applying it?
Regards,
eplpwr
Offline Yansi
  • STM32, STM8, AVR, 8051
Re: What is the white glue/goo/rubber that fixates high-rise capacitors called
« Reply #1 on: November 20, 2020, 07:27:02 pm »
It is some form of a non-acidic silicone.
The following users thanked this post: eplpwr
Offline wraper
  • Country: lv
« Reply #2 on: November 20, 2020, 07:30:50 pm »
Usually neutral RTV silicone adhesive rated for electronics. Sometimes 2 part adhesive might be used as well. You can buy it in western countries but it's expensive (EUR 25+ for 0.5L), usually comes in large tubes and has very limited expiry time.
But you can get 45ml tubes from China for a few bucks delivered. There are several types with different properties and are named with 701-708 numbers. Once opened it's advisable to put it into moisture barrier bag with silica gel desiccant so it does not get spoiled during storage. For example 706 I got from China is better than 3 types from ACC silicones I tried in the past. https://aliexpress.com/item/1005001608574673.html
« Last Edit: November 27, 2020, 06:35:00 pm by wraper »
The following users thanked this post: eplpwr, I wanted a rude username
Offline ambrosia heart
  • Country: hk
« Reply #3 on: November 21, 2020, 02:06:09 am »
Sorry, did not read your composition thoroughly.
See photos. Read 1st photo words carefully
before you buy. :popcorn:
How about the quality of 704?  one word: good.
  • Junior VoltNut
« Reply #4 on: November 27, 2020, 06:18:29 pm »
Thanks for all the feedback, I've now ordered types 706 and 707 to try out.
Best regards,
eplpwr
Offline Labrat101
  • Regular
  • Renovating Old Test Equipment & Calibration ..
« Reply #5 on: November 29, 2020, 08:54:55 pm »
Don't use RTV or any thing similar  .They use a mixture of rubber solution . The nearest you will find to day is Polymer rubber. 'Super 7 Fast Fix'  dries to non Harding Polymer rubber and does not cause any damage .
I have some were a book on how to make this . But I can't remember off hand where it is.Going back 50yrs .. we mixed puncher glue . ( bike repair kit stuff ) had a tube of liquid Rubber. We had a large tin in the workshop . but that was in the days when health & Safety was not an issue.
The other ingredient I can't remember for the life of me what it was called .
 Acrylic 2 mix dries like glass and is not flexible.
 I use polymer Rubber works fine . And can buy it normally at any good builder supplier .
Second option HOT Glue is nylon and works well . an stays flexible.
Good Luck  :popcorn:
« Last Edit: November 29, 2020, 09:11:02 pm by Labrat101 »
"   All Started With A BIG Bang!! .  .   & Magic Smoke  ".
Offline The Soulman
  • The sky is the limit!
« Reply #6 on: November 29, 2020, 09:02:40 pm »
Good Luck  :popcorn:
I'm using hot glue for that as well, surfaces may need a wipe with some alcohol for it to stick tho.
Offline Labrat101
  • Regular
« Reply #7 on: November 29, 2020, 09:16:13 pm »
Quote from: The Soulman on Today at 09:02:40 pm>Quote from: Labrat101 on Today at 08:54:55 pm
Good Luck  :popcorn:
Hot Glue I forgot to mention is not good in really hot spaces ..
Polymer is better as it has a good heat transfer . and good High voltage resistance  10kv plus
I have not used it on anything higher than that .
Offline wraper
  • Country: lv
« Reply #8 on: November 29, 2020, 09:18:37 pm »
:palm:  |O
Good Luck  :popcorn:
Yeah, good luck with crap you suggested.
« Last Edit: November 29, 2020, 09:20:24 pm by wraper »
Offline wraper
  • Country: lv
« Reply #9 on: November 29, 2020, 09:35:18 pm »
Don't be surprised when you find it delaminated from surfaces after a few years or almost immediately when device was used at low temperatures.
Offline Labrat101
  • Regular
« Reply #10 on: November 29, 2020, 09:39:07 pm »
@ wraperQuote
I am not getting into an argument with you . But I am sorry you are wrong
by making that comment . And there are many reports from Universities and document on this subject . Polymer pro's and cons and RTV 's .
Not Hard feeling  :popcorn:
« Last Edit: November 29, 2020, 09:41:04 pm by Labrat101 »
Offline wraper
  • Country: lv
« Reply #11 on: November 29, 2020, 09:43:25 pm »
Some random crap from hardware store of course is 'better' than RTV silicones specially marketed for electronics use and with specified dielectric parameters.
Offline wraper
  • Country: lv
« Reply #12 on: November 29, 2020, 09:46:06 pm »
If you don't believe that chinese selection table, here is a datasheet for western stuff: http://www.farnell.com/datasheets/1974040.pdf
Typical Applications
Assembly of electrical and electronic equipment
Sealing of corrosion sensitive devices
Shallow encapsulation of small circuits and connectors
Offline Labrat101
  • Regular
« Reply #13 on: November 29, 2020, 09:54:54 pm »
Quote from: wraper on Today at 09:43:25 pm>Quote from: Labrat101 on Today at 09:39:07 pm
And you believe that crap from ali express . 99% of that stuff is fake $1.66
If you want to think that stuff is tested .  :-DD .  The Joke is on you .
I would not trust that on 5 volts ..
 .. Ali china stuff NO. WAY
Offline wraper
  • Country: lv
« Reply #14 on: November 29, 2020, 10:02:15 pm »
Those silicones are for Chinese internal market and are standardized types made by many manufacturers. Nothing wrong with them. Not to say you ignored datasheet I provided for western stuff. Also sorry, but I will trust Chinese neutral silicone (by it's nature non corrosive) rated for electronics, compared to some random stuff completely untested for anything electricity related. BTW I know by experience that hot glue does not last in any conditions.
« Last Edit: November 29, 2020, 10:03:56 pm by wraper »
Offline Labrat101
  • Regular
« Reply #15 on: November 29, 2020, 10:15:43 pm »
I did read the other list.And we did test that stuff .. it smells horrible when it burns .Plus it has a high PH and it is corrosive . No 2 tubes are the same. It also failed .. So if you like it .. enjoy it.
Offline wraper
  • Country: lv
« Reply #16 on: November 29, 2020, 10:21:36 pm »
Dunno what you tested but it seems you are completely ignorant about difference between acetoxy and neutral curing types. Silicones do not burn BTW, at worst they disintegrate at high temperature.
