Author Topic: Motherboard repair  (Read 694 times)
Offline gtrakTopic starter
Motherboard repair
« on: March 09, 2021, 07:28:46 pm »
Hello folks, I have a ASUS X399 motherboard. I blew it up by plugging in a PCI-E card backwards when off, shorting some standby voltage. I smelled some smoke, and now the power button does nothing. I think I found what I blew up!  I found a hard bubble on top of the top transistor in that pictured cluster.
I have a picture from a replacement board, but can't seem to identify the component.
Can you fine people help? If it's really as easy as replacing this, it's definitely worth a shot for me to try it.
WAG71??
Offline james_s
Re: Motherboard repair
« Reply #1 on: March 09, 2021, 07:39:42 pm »
I found one hit for the WAG marking that sounds promising, PDTA144VT which is a PNP transistor in a SOT-23 package.
The following users thanked this post: gtrak
« Reply #2 on: March 09, 2021, 09:59:00 pm »
I was able to source some PDTA144VT,215, will give it a try, thanks!
Offline perieanuo
« Reply #3 on: March 10, 2021, 02:03:00 pm »
any pnp 'big' enough will pass the test ... or not
