Ceramic MLCC capacitors can crack such that opposite layers can short. However, it might only be a thin strand of the conductive layer. Therefore it could have a cold resistance of 15 ohms, but when it heats up there is enough thermal expansion to reduce the connection to perhaps 100 ohms.
Expect a current of 5V/100ohms = 50 mA, and that it dissipates 250 mW.
That can be detectable on a thermal camera, but it will be difficult to feel directly.
However, because it seems to be consistent, there are some diagnostic methods you can use:
1. Gently twist the board. Does the reading change?
2. Press on the parts when it's powered. Does the reading change?
3. Spray on the parts when it's powered with that compressed air spray. It cools down the part, so the reading might change.
