I had a Holden Camira (1980s GM "J series world car").
It had Bosch electrics, so I never anticipated "Lucas-like" problems, but they happened!
On one occasion, it refused duty after I had just stopped at a shop for a cold drink.-----No spark!
On investigation, I found that, unlike all others I had seen, the rotor button wasn't a direct connection, but had a resistor embedded in between the centre & the part that "distributed" the spark.
In fact, this no longer had a resistor, just a "pit" burnt into the bakelite.
What the hell to do?
I happened to look down, & there was a discarded cigarette packet, so scrunching the foil up, I rammed it into the pit, the car started & ran OK, getting me home.
On another occasion, it was a wet, winters day, & it again refused to start---this time the coil was extremely hot.
There were puddles of water all around, so I went through half a box of tissues, wetting them & draping them around the coil.
After about 10 minutes of this, it cooled enough that the car would start, & it stayed cool long enough to get home.
It was cool enough next morning to run till I got to the car parts place for a replacement coil!
Another time, we were sitting at the petrol pump at a country Service Station, when after paying, the car refused to start.
This time, it had "eaten" the distributor brush!
Luckily, this was an "old school" place, so the proprietor & I sifted through his junk box till we found a brush that would fit, & we were on our way again.
