Author Topic: Motorola 24A Diode Replacement  (Read 1726 times)
Offline warf135
    • Normsweb Tektips
« on: July 05, 2015, 07:24:18 pm »
Hello, I'm repairing a radio that uses an SMD Motorola diode for reverse polarity protection on its power line.
The diode is marked: 24A and from what I can tell, is either: 1.5SMC24AT3 or: P6SMB24AT3 I need to find a suitable replacement for this diode.
Here is a pic of the blown diode:
I'm pretty sure that -being used only for reverse polarity protection- its not important to get an exact match... Any Ideas?
Thanks in advance!
Norm (aka warf135) - Not Strange, Autistic.
Online T3sl4co1l
    • Seven Transistor Labs
Re: Motorola 24A Diode Replacement
« Reply #1 on: July 05, 2015, 07:29:36 pm »
That's a TVS, not just reverse protection.
Probably, anything SMB/SMC of the same specs would do; SMCJ24A is quite common.  (Make sure it is not the -CA version, which is bidirectional and won't provide reverse polarity protection!)
Do measure the package to verify which one it is (SMB is smaller than SMC).
« Last Edit: July 05, 2015, 07:31:18 pm by T3sl4co1l »
Seven Transistor Labs, LLC
Offline warf135
    • Normsweb Tektips
« Reply #2 on: July 05, 2015, 07:56:58 pm »
Thanks for your quick reply!
Service manual for radio states that it is there for reverse polarity protection no mention of TVS :-//  (and sadly no parts list in the service manual i have) I will try to measure the diode soon.
Cheers!
Offline warf135
    • Normsweb Tektips
« Reply #3 on: July 10, 2015, 08:34:22 pm »
Hello, apologize for delay I have been unwell...  Original diode is about 7mm x 5mm.
Online T3sl4co1l
« Reply #4 on: July 10, 2015, 09:08:28 pm »
7-8mm body / overall, should be SMC then.
Offline warf135
    • Normsweb Tektips
« Reply #5 on: July 10, 2015, 09:50:08 pm »
Thanks, SMCJ24A ordered!
