Author Topic: Help identifying SMD transformer  (Read 472 times)
Offline CTDTopic starter
« on: October 15, 2024, 11:51:18 pm »
I'm repairing a very expensive Honeywell temperature controller, and ran into a shorted transformer. It's part of a VFD display board, so I'm assuming used to generate the needed voltages to drive it.
It's the 8-pin part labeled 006 YW (and 006 YX- on an identical board).
I can't seem to find any information on it, does anyone know how to identify it?
Thanks.
2403475-0
« Last Edit: October 15, 2024, 11:53:14 pm by CTD »
Online inse
Re: Help identifying SMD transformer
« Reply #1 on: October 16, 2024, 05:49:22 am »
Might become difficult, probably it’s a custom wound transformer.
I have little hope that spare parts are made available by the manufacturer.
If you have a functioning unit, measure the required voltages.
Is there space to bodge in a separate converter module?
« Last Edit: October 16, 2024, 06:10:41 am by inse »
« Reply #2 on: October 16, 2024, 08:25:12 pm »
That's unfortunate. I guess the best option is to try and pick up a dead one off ebay for the display board/transformer. The one I'm working on seems to have been victim of a power surge or incorrect voltage. The power supply board had burnt parts all over but was fairly easily repaired. Thankfully the logic board didn't suffer any damage and is the only one that changes with the specific part number so sourcing the display part is fairly easy.
Offline Harry_22
« Reply #3 on: October 16, 2024, 09:00:22 pm »
... and ran into a shorted transformer.
Hi!
How did you determine that the transformer is shorted?
The probability of such parts failure is very small.
Online inse
« Reply #4 on: October 16, 2024, 09:11:46 pm »
The way the board looks, the transformer is toast…
« Reply #5 on: October 16, 2024, 09:13:21 pm »
Desoldered it and compared with the one on a good board. It has continuity between pins that are not connected to each other on the good one. If you look at the picture, the transistor near the coil was completely burnt, lifting the soldermask.
Offline Harry_22
« Reply #6 on: October 17, 2024, 11:01:37 am »
Would you like to disassemble and rewind it?
I can try to disassemble a similar one to understand how it works. It seems to have a ferrite O-ring around the spool.
