Hi All,
I purchased a MS3010D bench supply from ebay. Upon powering it on, pressing the "Power" button on the front of the unit, there was a loud band and flash, the power in the house went off. Upon inspection of the unit, at the sellers request, I found that the mains wires to and from the front power switch were running directly under the PCB. One of the legs from a component had pierced the live cable and sent 240v into the circuit. I believe it was pin 4 of the 817C optocoupler, which blew the bottom of the IC off and destroyed the track from pin 3 of the 817C which goes to pin 4 of the DK112 power controller. I have checked a lot of the components around these chips and along the traces and the Capacitors and resistors all seem in spec. Most tested in circuit, I did remove a few caps and tested them to make sure as they were in direct line of the 240V. I only found 1 diode at D10 coming off pin 2 of the 817C that is a dead short.
The seller has refunded me for the supply and told me to keep it, so I'd like to repair it as a project. I am by no means an electronics engineer, I class myself as a novice, it is a hobby to me, I have recently repaired my Commodore 64, which went faulty about 25years ago and have always been interested in electronics, repairing gaming consoles and modifying them. The C64 was a learning curve for me. So after testing the basics, would it be feasible to repair this PSU by replacing the two IC's and the diode? Is there anything else I need to check/test? I have attached some images to look at.
Regards
Rob
