Lower the resistance higher the current but the terminology, speaking for myself, gets muddy.
Well, there is a thing called conductance, which is the reciprocal of resistance.
It's usually not spoken of much.
We do kind of have these traditions like the idea that current flows from plus to minus.
Maybe we should have decided that the electron has a positive charge, it would have made life easier.
In any case, voltage and current are like two sides of a coin.
Most statements about either one could be turned around to say something about the other.
"The sum of currents into a node is always zero." => "The sum of voltages in a loop is always zero."
Take a 12 V battery. Nothing connected. What's it doing? Nothing. Power = 0 Watts
Put a 3 Ω resistor across it. Current flow = 12 V / 3 Ω = 4 A, Power = 12 V * 4 A = 48 Watts
Take a 4 Ampere current source with the output shorted. What's it doing? Nothing. Power = 0 Watts
Insert in the loop a 3 Ω resistor. It develops a voltage across it = 4 A * 3 Ω = 12 V, Power = 4 A * 12 V = 48 Watts
Insert in the loop a 5 Ω resistor. It develops a voltage across it = 4 A * 5 Ω = 20 V, Power = 4 A * 20 V = 80 Watts
Ok, but a battery can only deliver so much current, right?
A current source can only "accomodate" so much voltage.
We can't have anything having infinite power!
Insulators and conductors, are also two sides of a coin.
We live in a world where insulation is cheap and conductors have to be specifically made.
When I make a little flashlight, I need a battery, a bulb and two wires.
I don't have to go out of my way to insulate anything.
When the aliens who live in pools of mercury want to make a flashlight
they'll need a battery, a bulb and at least one insulating sphere (containing the ambient mercury).
