Hello everyone, I have a Msi rx 570 armor 8gb that stopped working, and I decided to give it a try and try to figure out what was wrong with it and try to fix it. So I started measuring all the power lines, and then I tried to check the enable signals in the buck converters since all what was missing seemed to be the power to the memory and the gpu, but while doing so I accidentally shorted something so a 2R2 resistor inmediatelly started smoking.
So I replaced that resistor but now I have a short to ground in the 12V power line that I can't figure out where it is coming from.
Any ideas or suggestions on how to continue? I am quite new to this kind of stuff and I think I ran out of ideas.
I leave a couple pictures of the board. I have shown in the front one the resistor that I replaced.
Thank you in advance for your help
