Aside from being careful of tiny connections and delicate parts in general, you should know that the "BeO" on the label refers to Beryllium Oxide, used somewhere in the internal construction.
An innocuous looking white ceramic material, it is VERY toxic if abraded and inhaled. Unless you are planning on grinding or machining the internal parts, you should be fine. It is used where an electrical insulator with good RF properties also needs to be a good thermal conductor. Probably located between the heater element and the YIG element itself.
