Author Topic: Multipole connector  (Read 2110 times)
Offline wissTopic starter
Multipole connector
« on: December 17, 2014, 04:13:37 pm »
I'm trying to repair the cable for a turbo-pump, one, several, wires have broken close to the connector.
How can I open it?
Offline 8086
    • Circuitology - Electronics Assembly
Re: Multipole connector
« Reply #1 on: December 17, 2014, 04:15:40 pm »
You need to hold the central part that has the holes in it, and the back part will unscrew.
« Reply #2 on: December 17, 2014, 04:35:40 pm »
Thanks!  :-+
« Reply #3 on: December 17, 2014, 05:31:55 pm »
You will also need the plastic extraction tool, and new socket inserts. Those are available from RS in the circular military connector side. 19 pin circular locking connector.
http://docs-europe.electrocomponents.com/webdocs/009a/0900766b8009a033.pdf
RS part  494-521 seems to be the one you want.
Offline helius
« Reply #4 on: December 17, 2014, 06:29:21 pm »
You need to look closely at the part number on the connector. PT 06 E 14-19 S is a MIL-C-26482 Series I "Matrix" connector with (non-removable) solder contacts, MS3116. The removable crimp contact version would be labelled "PT 06 SE". So you will need to desolder the wires from the contacts in the connector you have. It would be best to cut the wires first to avoid damaging their insulation.
See http://www.amphenol-aerospace.com/pdf/12-070.pdf
