This is good stuff!
I own two restored TDS420's. One with FFT (2F is printed on the serial number sticker). The other has no options other than the Centronics/RS-232 card.
I may slip the covers off to see what is present in the corner of their Acquisition boards
The re-capping of the Back-plane board is now behind me! Thanks to Hakko too. I don't use the de-soldering tool very often, but when the circuit board is clean and it's through-hole parts in need of removal, it can't be beat.
What's left on the list to be done is the replacement of the CPU board battery. After that, it's assembly time.
At this point, I can only hope I caught everything that needed fixing. The seller of the scope said that the TDS460 fails its initial self-tests and the Signal Path Compensation routine. I didn't power it up when I got it, I headed straight for the screwdriver!
*I went ahead and set the SMPS up on the bench to measure the amount of ripple on the +15 rail (pin 8 & 9). I used a 1x Tektronix P6101 probe and a TDS420 oscilloscope. Here's how the waveform looked DC coupled.
I then switched the scope to AC coupled. I needed to activate the "zoom" function to get a better look at it.
The waveform would show a spike about every second which is at 60 cycles/Hz causing the whole waveform to bounce a little. Is that spike normal and just due to the switching action of the power supply? And is it the diodes that are causing it? Anyway, the +15 VDC rail is rock solid with no fluctuation when measured on the DMM.
Is this a situation where a soft-recovery diode would be beneficial/used?
Anyway, together she goes!
