Author Topic: My monitor won't turn on unless I remove power completely first  (Read 2486 times)
Offline agehallTopic starter
« on: February 27, 2017, 11:02:05 am »
So my Dell U2711 (circa 2011 vintage) decided to die on me a couple of weeks ago. I cursed a bit, got myself a new screen and left the Dell on the bench. Basically, it didn't react to me pressing the power button.
When I got a bit of time, I decided to attempt a repair as I really liked the screen. The obvious problem would of course be bad caps so there was little surprise when I opened it up and found a whole bunch of bad caps inside. There were a few bad ones on the transformer boards and I also saw a couple of obviously bad ones on the logic board.
I proceeded to order all the caps from Digikey and started replacing them. Unfortunately I managed to mess up my order and got a whole bunch of caps with the wrong values. I proceeded to replace the ones I did order correctly and decided to test the monitor out. Turns out it now switched on without any issues so I reinstalled it on my desk and used it.
However, the next day, it again refused to turn on. :( However, what I did notice, was that if I remove the power cord and reinstall it, it works again.
My plan is to replace the caps I didn't get to the first time around and hope that fixes the problem, but is there anything else I should be looking for that is typically a problem as well?
Offline CJay
Re: My monitor won't turn on unless I remove power completely first
« Reply #1 on: February 27, 2017, 11:07:20 am »
Replace the caps with correct values (higher voltage is acceptable) and equivalent or better ESR values, check your prior work.
Also check high value resistors, it's possible something has gone open circuit or risen in value.
Online nctnico
« Reply #2 on: February 27, 2017, 11:10:47 am »
I've seen this happen before (high value resistor broken) which caused similar symptoms.
Online wraper
  • Country: lv
« Reply #3 on: February 27, 2017, 11:23:24 am »
Don't bother with measuring any resistors before replacing small capacitor(s) on the primary side.
« Reply #4 on: February 27, 2017, 11:32:29 am »
Thanks for the replies!
All the caps on the primary side were replaced with proper new ones.
There are about 35x 47uF ones on the logic board that I didn't touch as I managed to order 470uF ones.
I'll take a look at the resistors as well. It will be a bit tedious, but hey, that's what spare time is for, isn't it. :)
Offline CJay
« Reply #5 on: February 27, 2017, 12:00:07 pm »
Definitely, my rule of thumb is 'if it's got a 4 and a 7 in the value, it's probably faulty' when it comes to capacitors in power supplies but they tried to fool me and started fitting 22, 10 and even 100uF capacitors so your advice is better :)
I should probably have said if the fault persists then check resistors but I would be checking any resistors that are intended to provide a 'startup' or 'kickstart' supply if I had those symptoms anyway.
Offline Armadillo
« Reply #6 on: February 27, 2017, 12:49:34 pm »
The description fits a OVP or thermal latch up protection that need power supply recycling to reset. However, I supposed some failed capacitors may camouflaged and imitate the same symptoms as well. Until then....
Offline james_s
« Reply #7 on: March 03, 2017, 08:02:26 pm »
I hate that. I have the same problem when I go looking through my parts stock for something. If I need a 33k resistor I'll find 3.3M, 330k, 3.3k, 330 ohm, maybe even 33 ohm or 3.3 ohm, but no 33k. Seems like it happens every time.
