Author Topic: My Motherboard Released the Magic Blue Smoke!!! Update: It Lives!!!  (Read 10917 times)
Offline iamdarkyoshiTopic starter
Hello everyone. My gaming computer released the magic blue smoke today when I plugged in a faulty DVI cable into the onboard graphics. This cable had given me troubles before when I used it on my normal graphics cards, but the cards just simply shut off instead of exploding things. I decided to mark the cable as defective using the Photonicinduction method that way I wouldnt mix it up with my other 50 spare cables.
Anyway, when the cable was plugged in, after about 10 seconds I smelled the smell that we are all familiar with. However, the PC kept going. My eyefinity monitors weren't disturbed, and the audio I was playing continued to play. I shut the machine down immediately and unplugged the cable once I smelled smoke.
Is this machine still safe to operate? Or should I desolder the blown component? I have had SMD soldering experience. If I desolder anything, what should replace it? The failed component appears to be D8, a diode?  I have some low-tech marco photos of the only visibly failed part as well as the annihilated cable in a .zip file, and they can be found full size here: https://drive.google.com/file/d/0B-LjUeh-cirIeVJTbEYwa1pUMnc/view?usp=sharing
Motherboard is an Asrock Z77 Extreme4 if anyone has the same board.
Thanks!!
« Last Edit: May 07, 2015, 11:19:18 pm by iamdarkyoshi »
Offline romantronixlab
Re: My Motherboard Released the Magic Blue Smoke!!!
« Reply #1 on: April 26, 2015, 01:25:01 am »
Picture would be best to attached to the post for later reference.  Was not able to open zip.
The diode most times is not just what could be gone, check also for regulators and resistors near the dead Diode. and component.
Will think about it.
« Reply #2 on: April 26, 2015, 01:26:12 am »
Sorry about the .zip, I did not want the photos compressed.
« Reply #3 on: April 26, 2015, 04:21:26 am »
Images can be found as direct uploads here:
Sorry, the forum wants 1mb max per file, and 2mb total. My photos are about 2.5mb each.
Offline Grapsus
« Reply #4 on: April 26, 2015, 09:18:35 am »
You can fit a lot of pictures in 2 MB, the trick is to crop, resize and use 80 as JPEG compression factor, not 95.
Did you test the diode with a multimeter ? Is it internally shorted or open ?
« Reply #5 on: April 26, 2015, 12:44:50 pm »
I have not. A bit later today I will remove the board and get out my multicore desoldering braid and electrolube flux and removs the part. It must not be critical considering that it kept running...
Offline JBaughb
« Reply #6 on: April 26, 2015, 12:56:46 pm »
Im not sure if thats the correct way of looking at it...
« Reply #7 on: April 26, 2015, 12:59:40 pm »
Ya probably not... I do think that the onboard graphics are nonfunctional now because after the smokd it played the "hardware unplug" sound.
« Reply #8 on: April 26, 2015, 06:55:52 pm »
Now I think that the component was an "LNW 24" as there are many elsewhere, but the board designators are inconsistent. See photos
Offline SL4P
  • There's more value if you figure it out yourself!
« Reply #9 on: April 26, 2015, 09:20:59 pm »
D8 is unlikely to be the same component as Q anything...
Look for another D in the same package - and you MAY be half way there - but not for sure.
Ideally find someone with another board and check a known uncooked part
Don't ask a question if you aren't willing to listen to the answer.
« Reply #10 on: April 26, 2015, 09:40:01 pm »
I have found someone on the linustechtip forums. Awaiting response.
Offline Rasz
    • My random blog.
« Reply #11 on: April 27, 2015, 07:50:48 am »
why not use continuity tester and check pins of this component against dvi pins? it looks like a clamping diode, maybe on +5v DVI provides?
Offline rob77
  • Country: sk
« Reply #12 on: April 27, 2015, 08:16:22 am »
+1
actually it looks like a dual diode in sot23 - and apparently only one side is blown.
Offline bktemp
« Reply #13 on: April 27, 2015, 08:52:54 am »
LNW = 2N7002 = N-channel mosfet
This matches the Qxx on the board.
Offline macboy
« Reply #14 on: April 29, 2015, 02:53:27 pm »
Highly unlikely. "Q" indicates a transistor, in this case a MOSFET. "D" indicates a diode. Either can be in a SOT package.
« Reply #15 on: April 29, 2015, 03:10:05 pm »
Which is what made me skeptical. However, the blown part has a clearly visible L, a somewhat visible N, and possibly a fainly visible W? Also, the board's designators are hard to understand. I cant find anything else in the area that could be a diode though. I am in touch with another owner of the same board, and he is going to get me some photos of his.
Offline senso
  • Country: pt
    • My AVR tutorials
« Reply #16 on: April 29, 2015, 10:38:03 pm »
I can tell you the obvious, PQ is Power Transistor/Mosfet, SQ is Signal Transistor/Mosfet.
Offline macboy
« Reply #17 on: April 30, 2015, 01:38:06 pm »
That is the best course of action. No guessing.
« Reply #18 on: April 30, 2015, 03:18:30 pm »
Or perhaps sparkfun's "magic blue smoke refil kit"
« Reply #19 on: May 04, 2015, 03:28:10 am »
Alright everyone, got some details from the Asrock forums:
parsec wrote:
OMGosh, a photo of that part would require a macro lens on a digital SLR camera.
Using a high power magnifying glass and two lights I was able to see the markings, clearly after several attempts. It is:
LNW 22
The 22 is rotated 90 degrees counter clockwise relative to the LNW. This part is labeled D8 on the board, so apparently is a diode.
You'll need better luck than I had reading that part, trying to replace it IMO. You must have experience with surface mount devices as well as the tools to work with them.
Good luck with this project!
So that is what we have for information. Any chance I would find this same part on another older scrap motherboard? How does one read the marking on these parts?
It lives!! Both the onboard and the crossfired graphics cards work! I used a mosfet that had similar specs stolen from a scrap Pentium 4 mobo , and aside from a different number, it looks new. Thanks everyone. Now to get back to CAD work. And games  :popcorn:
Offline gildasd
  • Engineering watch officer - Apprentice Officer
    • Sci-fi Meanderings
Cool! Job well done!
I'm electronically illiterate
Offline jaycee
Re: My Motherboard Released the Magic Blue Smoke!!! Update: It Lives!!!
« Reply #22 on: May 10, 2015, 05:03:42 pm »
If this was on the DVI output pins, it was likely a dual diode wired up as a "catch" diode.. one to +v and one to ground. It's likely your faulty cable caused a short to a higher supply. You can also get this happening if you have no power ground and a chassis is floating at half mains.
