I bought very cheaply a lot of stock room capacitors (still in sealed bags of 50); electroytics and orange drops, polyester and tantalum. All name brands. As I pull them out I test them with the tweezers but "needed" a way to test for leakage.
Then I found a variable 300 volt DC 30mA variable supply for $20. With a 6.3VAC tap.
I looked at the various ways people executed their enclosures for the AWA test board. I placed the outputs in the rear and as far apart as practical. I made my test clips short enough to avoid them shorting yet long enough to keep large electroytics above the case. I decided on a SPDT switch with a center off. Test/off/Discharge. The discharge is thru a 33
5 watt resistor. The center off allows me to confirm the cap is fully discharged, or I can time its discharge.
The voltmeter uses a simple bridge rectifier with a 220uF cap powered by the 6VAC tap off the power transformer. I decided the voltmeter should be on the enclosure and the ammeter SHOULD be external to the system. This means that the output is not energized unless there is an ammeter in the circuit. Another point of safety.
While the supply is rated at 300 volts, it does hit 380 volts. This should satisfy my needs. It has a very nice Stancor autotransformer whose diameter is about the same as the case height.
Of course I found the supply after I ordered the AWA board.
