Author Topic: Mystery Diode?  (Read 1446 times)
Offline SirAlucardTopic starter
Mystery Diode?
« on: May 03, 2018, 06:23:03 pm »
Hey all, I'm at a loss in identifying this SMD component. It's found right near a USB connection of a device I'm repairing. It's labeled as D1 unfortunately it's the only D that has 6 pads. Somehow the majority of the chip got broke off and the only identifying thing on it is a "K". The dimensions of the chip are ~2.9mm X ~1.6mm X ~.95mm and From what I can tell the center pin pointed out in the photo below is ground. If anyone can lead me in the right direction into getting this chip replaced. It'd be greatly appreciated.
Offline helius
Re: Mystery Diode?
« Reply #1 on: May 03, 2018, 06:35:21 pm »
That will be an ESD suppression/TVS diode marketed for USB applications. NXP, ON Semi, ST, and TI all make these and the pinouts should be compatible.
The following users thanked this post: SirAlucard
Online PA0PBZ
Re: Mystery Diode?
« Reply #2 on: May 03, 2018, 06:47:15 pm »
Yes, have a look here: http://www.littelfuse.com/products/tvs-diode-arrays.aspx
Re: Mystery Diode?
« Reply #3 on: May 03, 2018, 09:14:09 pm »
Here's a bit more info that I could figure out. These are the pin-outs from the USB to this chip.
Re: Mystery Diode?
« Reply #4 on: May 04, 2018, 01:48:07 am »
So I found this by ON Semi, it nearly perfectly matches the one I took out.
https://www.mouser.com/datasheet/2/308/NUP2114-D-120263.pdf
However couldn't find any from the other manufacturers.
