After three months in the drawer the battery was low and it would not turn on. After charging the battery, now the device just provides a messy response, with no resemblance of the antenna connected to its SMA connector. It now displays dips and peaks a few MHz apart, continuously across the entire spectrum. Display is the same if a 50ohm dummy load is connected or if the antenna connector is left open circuit, although the position of some peaks change when the dummy load is attached.
I have reset the device without effect. Battery voltage is 4.13v
I purchased the device from Banggood and they will not accept a warranty return after 12 months. I cannot find contact details of the manufacturer AAI (Accuracy Agility Instruments) Any thoughts on how I might restore the proper operation of this device will be greatly appreciated.
