Amps with distortion or disapearing audio on single or multiple channels on low levels (comming back on higher levels or more bass) usually mean the speaker output relays. This can easely be checked by cleaning the contacts with some paper and IPA, or bypassing them with a wire.
If it only gets worse or better when turning the pots or input switches, you guessed it, it's probably the responding pot or input switch.
If both are not the case, look for bad solder joint, starting at the output transistors.
