I did plan ahead for this moment. I stripped my chassis and cleaned the CRT assembly last Fall.
I started the assembly process by re-capping and installing the backplane board:
The power supply was cleaned, re-capped, new TVS installed, all solder joints re-flowed, and bench tested:
The make-or-break though is CaptDon's Acquisition board. I re-capped it tonight. CaptDon said that the scope passed SPC before the power supply went south. What I found was every original electrolytic capacitor was wet but there was minimal damage. I did find and repair one SMD ceramic capacitor near a leaking electrolytic capacitor with no continuity off of its soldering pad. We'll cross our fingers! I could not find any other lost connections:
I like using leaded electrolytic capacitors since they are easy to install and because I have a bunch of them!
The battery on the DSP board measured over 3 volts, so it was left alone. The CPU board battery was hovering around 2.6 volts, so it was replaced:
The Display board is part number 671-1784-02:
I know by now to go straight to inspecting and cleaning boards soon after pulling the scope from the shipping box. This is the membrane behind the front panel board. The leaking electrolyte makes its way through the holes from the scale knobs and gets trapped in the sandwich. It attacks the carbon and copper traces from behind. If your scale knob skips a step, this is where to look:
Even though CaptDon's Front Panel board had all of its original capacitors leaking, the board itself is in excellent condition. I'll be saving it for another project since I already have another FP board re-capped and ready to go:
I also cleaned and re-capped the RS-232 board:
