I'm just starting to get into trying to repair some simple things. I have a NAD C-316bee amp that was lost to a lightning strike a couple of years ago. I tossed it aside with the intention of harvesting some parts out of it, and finally got back to it. I decided to see if I could find the issue, and the first issue I've found is that the +/- 17V supply isn't working. I found a service manual for a C-315bee online, and that one appears to be very similar so I've been using that schematic. I have attached a PNG snip of the relevant part here.
Anyhow, I've been poking around, the transformer appears to be putting about 50VAC into the rectifier, and I'm seeing +/- 35V at R317 and R314 as expected. On the other side of R317 though I'm only seeing 0.08V and that's what I'm seeing on everything after that point in the positive side of the circuit. On the negative side, it settle at about -2.19 V.
Anyhow, I'm having a hard time figuring out what to test next. I'd appreciate any suggestions.
Thanks,
Chris
