Hi Guys,
I've read the comments and suggestions to fix a C165.
My C165 is dead. What happened is the following:
I pushed the power on, the front panel one (switch at the back is always on) but main power in the house was out.
Unfortunately main power came up at the very same moment I was pushing the power on (front panel).
Now the C165 doesn't respond anymore. No amber, red, blue light.
When I disconnect the main board with the small plug and white 3 cable ribbon cable 5,6v is available at C54 on poweboard.
When connecting the main board voltage drops below 1v. I replaced IC51 already...
As you've been digging somewhat in these circuits is there any clue that could help me and point me to the defect component ?
MANY thanks !
