Hi. I only have a basic understanding of electronic but I have had some luck in the past repairing things. More luck than judgement! On inspection my power supply had a couple of bulging caps witch I've replaced but still no joy. Basically the supply is a pc atx power supply. The 5v is good and when you ground the 5v sense the 12v begins to power up then back dead. Any advice on where to start looking to rectify this would be great. It's not a standard form factor so a replacement ain't really a viable option. Many thanks for any possible help.
