If you take the bottom cover off, you can pretty much inspect the motherboard for cracks or other issues... Don your optivisors and take a look at the connectors, to make sure they didn't get damaged when the cards were hit... With just a little luck, there will be no problem on the mobo!
Regarding washing the boards in alcohol... Unless there is a reason to do it (i.e. they look contaminated or there is reason to believe the surface is contaminated), is it perhaps less risky to leave them as they are?
Good advice indeed!
Of course, I was just too curious, and against perfectly good advice, I took the motherboard out and stripped the unit down to its bare metal frame skeleton. I took a chance and carefully peeled off the FLUKE labels on the handles and it turns out that the labels are quite thick and the adhesive remained strong while leaving no residue on the plastic of the handles. The labels were very easy to put back into place and it does not look any different than before. So it was a very nice surprise. Then, I was able to remove the hidden screws, removed the front frame, and released the motherboard out of the main frame.
The motherboard looks in great condition and carefully inspected it for solder problems but everything was nice and shiny. Skipping the bath, I gave the motherboard and air blast shower and then put it back into place.
Note for 8505A owners:The 8505A has a wonderfully modular design and built of quality (non-plastic) material. But the biggest design flaw that I can see is with the mounting of the Front/Rear Switch PCB Assembly with the motherboard on the right front part of the unit. This F/R Switch board hides in its own shielded compartment on the right side. Taking it out and putting it back into place was the most complicated part of the teardown process. There is little space and no room for error.
When removing the F/R Switch board, first remove the three vertical column of buttons and their extender rods before pulling the board out from the back. Be very careful, it will feel like the plastic extender rods will break, and there is a good likelihood that they might, but pull with a small twist to disconnect it from the pushbutton switches to which they are attached. (the plastic holding the spring actually fractured on the pushbutton for my Front/Rear input button, but the button still works so I shall leave it be.) Then, to release the F/R switch board from the motherboard sockets you must pull up the entire board using a tab protruding in the front next to the three vertical buttons on the far right side. Pulling up releases the board from the sockets (there are two sets, J3, J4, and J5, J9 on the schematic) of the motherboard allowing you to pull the F/R switch board out the back. These sockets were a problem for me.
I could not easily reseat the F/R Switch board back into these motherboard sockets in the front. They just would not insert back into the socket and there was little to no room to move it around. You could only hold the board from the small tab in the front and the input connector in the back. So I had to remove the motherboard and see why the F/R board would not seat into the sockets.
It turns out that socket J4 has a plastic block in blade position 2 that slides into a groove in blade position 2 of the F/R board. The block ensures proper positioning of the board with the motherboard socket. You can see this block in J4 of the motherboard in page 5-10 of the 8505A manual. Well, looking closely, this small plastic block was worn down and had gotten wider from past removal and insertion of the F/R switch board into and out of the frame over the years. The block was "blocking" the board from being reinserted into place. Fortunately the motherboard was removed and I was able to squeeze this worn down plastic block to a smaller size with a pair of needle nose pliers and then the F/R switch board was able to slide back into place. A squirt of DeoxiT helped lubicate things and it finally fit back into place.
I had to remove the motherboard to fix this and I would never have been able to put the F/R switch board back into place without the motherboard removed. The official procedure is to slide the F/R switch board back in from the back of the unit and blindly wiggle it around while holding the board from the back and the small tab in the front. It is obvious to me that from the amount of wear and tear on the plastic block on J4 that other people had similar problems with it in the past and mashing down the plastic block in socket J4 in the process. IMHO, this is the only real defect (a maintenance defect) with the 8505A, besides, of course, the totally awful crispy plastic that is used to contain all the modules.
I hope this is useful to other 8505A owners.
So, I was finally able to put my 8505A back together once again. The power came back on and it all looked as before. I cleaned all the connectors on all the PCBs with DeoxiT and I notice that the LED displays are much brighter than before. Very nice.
But it still couldn't switch out of V DC mode. The entire row of Function pushbuttons on the front panel had no effect. So, I tested the panel buttons (with my trusty little Fluke 101 DMM) and the buttons all tested good. Next I tested the diodes next to the buttons and found one that appeared to be open in both directions. Odd... So turning power back on, I tested the diode for voltage and found zero voltage, so I pushed on it a little harder to make better contact. At that moment I started hearing relays clicking and the Ohms reading came alive.
Turns out diode C4 on the Display PCB was cracked in half and was an open circuit. Pushing on it with my test lead caused it to conduct and make everything come alive for a moment. The cracked diode disabled the entire row of Function pushbuttons on the front panel. Looks like a clean crack in the glass of the diode. I am guessing due to the past impacts this little machine has suffered.
So now I have a functional 8505A that can make all DC measurements. Next problem, the system is not recognizing my AC Converter module for AC measurements.
And, the story continues...
