Does the screen do anything at all? Does it light up at all ? You can look up all the chips and make sure they have Vcc.
I'm guessing the big chip runs everything including the video, or maybe there's a smaller separate MCU that's the brains. Look up the chips coming from the ribbon cable, see if they are doing anything.
Are there any chips or PCB on the actual LCD panel? You replaced the screen, but anything on there still could give some indication of what's wrong.
I haven't had much luck with my old broken monitors, and I had to throw them out to save space.
