I made a mistake by passing more than 200mA in this multimeter, it seem a resistor is blown. Anyone with the same multimeter could give the resistor value? Thanks
Do you mean the 1R00 resistor (1
No fuse inside? You should add a fuse (200mA fast) or dump this "quality gear"...
No, I mean the resistor near the 1Ohm one, a fuse is still present but it doesn't blown
maybe because it's too cheap
