Author Topic: NEED EEPROM DATA - HP6034 60V/10A Power Supply  (Read 1583 times)
Offline PeepsTopic starter
« on: November 11, 2015, 02:57:15 am »
I purchased a non working HP6034A power supply off eBay recently. It shows the symptoms of a kernal failure - all LEDs and display segments light up and stay lit upon power up. There's an amazing thread about it here. The unit came with 2 replacement micro's (as it seems the seller found this thread) so I have a total of 3 and none of them make a difference. I replaced the memory with a pair of AM9112 256kb modules with no success.
Perhaps it is an issue with the surrounding glue logic? I wanted to rule out the big 3 before going further with the repair.
So if anyone has this supply and is willing to upload the EPROM data I would be happy to pay you for your efforts.
« Last Edit: November 11, 2015, 03:01:08 am by Peeps »
Offline picburner
Re: NEED EEPROM DATA - HP6034 60V/10A Power Supply
« Reply #1 on: November 13, 2015, 05:56:45 pm »
The only place where I found the HP6034A eprom dump is here:
https://github.com/bsdphk/PyReveng3/find/master
It is in an abnormal format, used as example in Phyton, but with some patience maybe you can reconstruct the code...
« Reply #2 on: November 15, 2015, 01:38:33 am »
Woah I didn't expect a result so soon. Thank you! I will report back once I've had time to work this all out.
