My Scopemeter 123 is broken.
Unfortunately, I replaced the battery with a battery where the polarities were reversed.
It fried resistors R504/506/507 and apparently nothing else.
I replaced these 3 resistors with equivalent resistors but it still does not work.
No ignition, no relay noise or buzzer.
I performed all the tests in the Fluke service manual and found no abnormality.
I have all the voltages necessary for starting including +3.3V.
All transistors and diodes are compliant.
According to the Fluke manual the software is corrupted and needs to be reloaded.
What is the procedure and what software do I need to reload?
Thank you for your help.
