Author Topic: Need help determining Connector-type from pictures  (Read 1272 times)
Offline Echo88Topic starter
« on: July 19, 2019, 11:22:22 am »
i want to find the manufacturer and name of the following circular 3pin-connector, which is used as the external power connector for Fluke 732A references.
Maybe someone here knows it and can give a hint:
https://xdevs.com/doc/Fluke/732A/732A_5/imgp/732a5_rear_1.jpg upper right is the 3pin jack which i mean
https://pasteboard.co/IoFZX0G.png picture of the plug, that i want to find and buy
https://pasteboard.co/IoG0lwD.png picture2
https://pasteboard.co/IoG0zsN.png picture3
Seems to not be a high quality connector, more like a plastic mini-XLR. Just substituting the jack against a more common connector is sadly not an option.
Offline mikerj
Re: Need help determining Connector-type from pictures
« Reply #1 on: July 19, 2019, 11:35:20 am »
No marking to indicate manufacturer?
These look similar: https://www.smithsinterconnect.com/products/connectors/circular/d-series/
« Reply #2 on: July 19, 2019, 05:21:26 pm »
Indeed, other names seem to be Hypertronics and Hypertac.  :)
https://www.datasheet.directory/index.php?title=Special:PdfViewer&url=https%3A%2F%2Fdatasheet.iiic.cc%2Fdatasheets-1%2Fhypertac%2FD01PB306NT.pdf
Think ill need D01PB306NT and YSK006--011AH/YSK006--089AH. Now i gotta find a distributor who stocks it and would sell it to me...apparently difficult according to digipart.
Offline syau
  • Country: hk
« Reply #3 on: July 20, 2019, 12:12:25 am »
I am also looking for it but not available. Please let me know if you find a distributor or we may able to share the quantity if they have minimum order.
