ISSUE FOUND:Conductive paint!!! I was making who knows how many shorts!? Of course nothing was working as intended! And I guess I'll have to consider myself lucky if nothing actually blew up, as it's apparently the case.
ORIGINAL POSTI'm having an issue with my home theatre system lately, that is driving me crazy... I'm a bit of a newbie though so please be patient with me even if I say something VERY stupid, which is quite likely I'm afraid.
I've recently had a sub fault (more on this later), it's a 15+ years old Infinity unit that according to service can't be repaired anymore due to lack of parts. So I decided to purchase a sub amplifier that felt like a nice drop-in replacement: a Monacor SAM-200D, connected to the RX-V671 via a single RCA cable --> sub out --> LFE in / left.
This brand new combo worked for like 15 minutes. Then, the sub apparently died. Whereas "died" means it stays in standby forever and nothing seems to be able to make it produce sound, i.e. power LED stays red, never turns green.
If I try to connect my smartphone to the L/R input channels of the Monacor, LED does turns green BUT volume is extremely low, nowhere near how it did for the 15 minutes it worked.
So... now I have no idea whether I have a faulty AV receiver, a faulty sub amplifier, or both!
Because you know, the 10+ years old Infinity subwoofer had the exact same issue: it turned on, but never left standby (LED stays red), the exact same issue I'm having with the Monacor. So this made me wonder: was the Infinity sub actually failed (by the way this would imply service didn't even check it as soon as they noticed it was too old, which I cannot say for sure), or was the Yamaha having an issue already before, that for some strange reason temporarily ceased to appear for the 15m the Monacor worked?!
Relevant settings on the AV: all speakers set to SMALL, crossover 80hz, subwoofer enabled, subwoofer level +4.0 dB (but tried up to the max, 10db, seeing no difference)
Relevant settings on the Monacor: crossover MAX, level/volume roughly at 50%
RCA sub cable checked for continuity, tried all sorts of playback stuff (Yamaha test tone, computer-generated 60hz sine, THX optimizer, blu ray discs, etc) that should have triggered the sub but... nada, nicht, zero.
I am able to do basic measurements/tests with a multimeter and/or an oscilloscope if needed (as a matter of fact I did the latter, and it feels like sub out is outputting... something! But I have no idea what I should be looking for in terms of waveform and/or voltage levels)
Any help would be greatly appreciated!
