haha... Yeah, sounds like there is something broken in the gun-plate support structure...
I still can't fathom quite how something would have possibly managed to break in such a way as to make it bend on the lower part and produce that wacky output you're seeing, though... Very, very strange...
I suppose it's probably already completely toast anyway, but generally if there is something loose and rattling around in a CRT, do NOT wiggle and flop it around with the screen pointed downwards even to 45° like was suggested above!! If there is anything loose in the envelope and it even briefly strikes the phosphor coating, for
sure you have instantly ruined the tube!!
There is a reason that tubes used to be shipped in cartons with the neck
DOWN and arrows on the outside of the carton saying
This Way UpI suppose that was all well before the modern shipper method of "oh, gee it says
fragile on it, maybe we should kick it around some"
