See attached for the ribbon cable, all I need is one. Does anyone know where I can find this? Any help is greatly appreciated.
FYI: It's an extremely fragile FFC used inside a Gateway LP2407 24" LCD monitor to connect the capacitive backlit controls on the side of the LCD.
PS: I traced over the "7" in photoshop because there was glare in the photo, making it unreadable.
PS#2: I think I see this cable on eBay but the cheapest one is like $10. This monitor isn't worth a lot.The pitch of the FFC is 0.5mm and the length needed is ~70cm (more is okay). I cannot seem to find a long enough cable. The only option seems to be buying some short 0.5mm FFC cables and then using 0.5mm pitch DIP adapters...hoping those fit in the monitor's case.
