Author Topic: Solved...... Need help finding an adjustment tool.  (Read 9769 times)
Offline AF6LJTopic starter
« on: April 06, 2016, 10:22:26 pm »
In the picture below you will see two adjustable coils a cap and a sub-miniature pot.
The object of concern is the pot; I need the proper adjustment tool for said pot...
Anybody have any idea where I can find this adjustment tool.
A regular screw driver won't work
« Last Edit: April 08, 2016, 12:12:25 am by AF6LJ »
Sue AF6LJ
Offline wraper
  • Country: lv
Re: Need help finding an adjustment tool.
« Reply #2 on: April 07, 2016, 01:03:58 am »
The screwdriver tip won't fit look again at the picture the adjustment part of the pot will not accept a flat blade.
Sue AF6LJ
Offline DTJ
« Reply #3 on: April 07, 2016, 01:13:29 am »
Its hard to tell from the photo - are you saying the rectangular section is not a slot but rather is a raised ridge?
If it turns easily, try getting a bamboo skewer and slot the end of it with a scalpel.
« Reply #4 on: April 07, 2016, 01:22:02 am »
The round part in the center is raised and accepts a round tip.
The slot on one side meets up with a blade attacked to the part that fits in the center. The outer ring moves not the center.
Sue AF6LJ
Offline sleemanj
  • Professional tightwad.
« Reply #5 on: April 07, 2016, 01:25:01 am »
So, you need a flat screwdriver without a center.
Get an old flat blade jewellers screwdriver from your junk drawer, get a hacksaw, cut a slot in the middle of the screwdriver's blade, job done.
Offline Ian.M
« Reply #6 on: April 07, 2016, 01:28:09 am »
Would a jeweller's screwdriver with a slot cut in the end to clear the centre 'pip' work?  If so, its time to attack a dollar store screwdriver with a Dremel cutoff disk.
Edit: looks like we have consensus.
« Last Edit: April 07, 2016, 01:30:35 am by Ian.M »
« Reply #7 on: April 07, 2016, 01:31:20 am »
improvised alignment tools seldom work well, I shouldn't have to make it.
On this forum someone should know what it is and where to get it.
Sue AF6LJ
Offline Muttley Snickers
  • Cursed: 679 times
« Reply #8 on: April 07, 2016, 01:50:51 am »
I did a quick search around as you probably already have and couldn't find much at all in the way of dedicated tool sets other than what I have linked below, given the same task I would simply knock something up on the lathe or find a hollow plastic tube of the same diameter and put in a notch acting as a keyway, sorry I can't help more.
http://www.tecratools.com/product1122.html
Offline MarvinTheMartian
« Reply #9 on: April 07, 2016, 02:06:55 am »
Just do a search on "security screwdriver set" - there are plenty of these available online and at hardware & electronics store.
I've attached a picture of part of my set and the bits that you are probably after (or are they too big? - hard to tell from your photo).
Bit sizes shown are: 3, 4 and 6mm across.
Reviving my old hobby after retiring! Know so little...only one thing to do...watch Dave's videos and keep reading the forum! ;-)
The following users thanked this post: AF6LJ
Offline fpliuzzi
« Reply #10 on: April 07, 2016, 02:56:06 am »
I know that you've said improvised alignment tools seldom work well, but in a pinch I have used ceramic tipped tweezers as a 'mini spanner wrench' to rotate tiny trimmers. The tweezer tips can be easily held to the necessary width to rotate the trimmer.
« Reply #11 on: April 07, 2016, 03:32:07 am »
I have those bits and the small one might work in a pinch...
I still want to see if someone has the tool...
What sucks deeply is the people who make those surface mount pots don't make an adjustment tool.  :palm: >:(
Sue AF6LJ
« Reply #12 on: April 07, 2016, 10:01:27 am »
Yes, I was thinking later, after I had posted my reply, that these may be on the large size.  :--
Indeed!  |O
Either they're thinking 'I'm right Jack, I've got my tool' or they expect you to return the unit for service (and not wanting you to do it!).  >:(
If you can't find the right tool, I think sleemanj and Ian.M's solutions would work well without too much effort. :)
Edit: Just found this tool (crap picture so I'm not positive it is what you want but you could contact them to find out). http://www.barnoelec.com/63doendhexto.html
« Last Edit: April 07, 2016, 10:31:14 am by MarvinTheMartian »
Offline rich
« Reply #13 on: April 07, 2016, 10:11:34 am »
I'm not sure I'm parsing the photo correctly, but don't you just need the negative impression of a regular flat bladed screwdriver? If so that seems common enough, I have at least one in my toolkit,and this trim kit has them:
https://www.circuitspecialists.com/8pk-a001.html
Offline tautech
« Reply #14 on: April 07, 2016, 10:17:07 am »
Bingo, rich wins.  :clap:
Avid Rabid Hobbyist
Offline Psi
« Reply #15 on: April 07, 2016, 10:18:21 am »
If it's an inverted slot then maybe its intended to be adjusted with just your fingers.
« Reply #16 on: April 07, 2016, 12:46:49 pm »
Indeed!  |O
Thanks; I'll check that out after I have had my morning coffee.... I'll post a drawing of the pot later, they sell them on Mouser among other places.
Sue AF6LJ
Offline gfiber
« Reply #17 on: April 07, 2016, 03:22:24 pm »
I have had sucess using a small flat blade screwdriver the fit on one side of the center of those pots. It can be a bit tedious but using that got the job done. Can't tell from the photo but some also have a small notch on the outside of the pot you can catch with the edge of a flat blade screwdriver.
Gary K8IZ
Gary K8IZ
« Reply #18 on: April 07, 2016, 03:28:43 pm »
I may have no choice. I thought I could find those pots online but they seem to be a customized version that are not regularly for sale.
Sue AF6LJ
Offline rich
« Reply #19 on: April 07, 2016, 03:36:39 pm »
was the kit I suggested not appropriate. I thought I'd nailed it :)
« Reply #20 on: April 07, 2016, 03:44:45 pm »
There is a blade needed to turn the pot however it is offset from the center and rotates around the indentation in the center of the pot.
There is one in that kit that might work but I can't see it well enough to tell... it is the third tool from the left top row...
Sue AF6LJ
Offline rich
« Reply #21 on: April 07, 2016, 04:01:50 pm »
Ah now I understand! This competition is harder to win than a keysight giveaway :)
« Reply #22 on: April 07, 2016, 04:17:02 pm »
I just want the proper alignment tool.
I just thought about this. That could be a machine adjustable pot...
 8)
Sue AF6LJ
Offline rich
« Reply #23 on: April 07, 2016, 04:38:00 pm »
So if it is machine adjustable, the correct alignment tool is an expensive machine... Sure you still want the proper tool?  ;)
I have random fork ended tools in the garage but none would be classed as proper alignment tools. Found this for you from an electronics supplier, but, again it's not a proper alignment tool.
Offline Gyro
« Reply #24 on: April 07, 2016, 04:40:41 pm »
Surely you just need to cut a slot in the end of a bit of plastic rod?  :-//
Best Regards, Chris
