Author Topic: Need help on identifying an IC & finding its datasheet (probably Sanken made?)  (Read 1973 times)
Offline dav
It's a SOP-8 PWM controller.
Its surface is a bit erased, I can read:
SC621
SK30
or something like this.
Any suggestions?
« Last Edit: February 25, 2017, 01:22:01 pm by dav »
Offline singapol
  • Country: sg
Re: Need help on identifying an IC
« Reply #1 on: February 15, 2017, 03:03:42 pm »
Could be this..a Sanken
    LED Light Management Unit Charge Pump,4 LEDs, 400mA Flash LED, Dual LDOs, and SemWireTM Interface
http://www.jotrin.com/product/parts/SC6210
Offline dav
« Reply #2 on: February 15, 2017, 03:15:45 pm »
Thanks for reply.
Mmm... strange, my device is a power supply  :-//
Offline dav
« Reply #3 on: February 15, 2017, 03:18:58 pm »
Wait,
the motherboard is Sanken branded! (it's the official power supply of a Sony TV/Monitor).
Maybe this PWM controller is used on power supply, too  ???
Offline 1kostik1976
  • Country: ua
« Reply #4 on: February 15, 2017, 04:43:49 pm »
/www.google.com.ua/search?q=sc6210&espv=2&biw=1600&bih=794&tbm=isch&imgil=Cu6M8lSQ2RgKlM%253A%253B53LgKiM9tf2QmM%253Bhttp%25253A%25252F%25252Fwww.elektroda.pl%25252Frtvforum%25252Ftopic2635890.html&source=iu&pf=m&fir=Cu6M8lSQ2RgKlM%253A%252C53LgKiM9tf2QmM%252C_&usg=__OmVvGJfnVZC0E-SjruTIDDqhLWY%3D&ved=0ahUKEwjsvM2qxZLSAhWFDCwKHa4QCbsQyjcIJQ&ei=Z4SkWKztGoWZsAGuoaTYCw#imgrc=Cu6M8lSQ2RgKlM:
Offline dav
« Reply #5 on: February 21, 2017, 06:11:08 pm »
I cannot find its datasheet, neither on official website (Sanken SC6210).
Just tried on jotrin, but after login it redirects on sanken website and nothing...
Any help would be appreciated.
« Last Edit: February 21, 2017, 06:16:23 pm by dav »
Offline amyk
Reverse-engineer the schematic a little bit and find its pinout. It might be FAN6210, A6210, or some similar rebranded IC.
It might also be SSC6210:
http://www.sanken-ele.co.jp/en/news/contents/20070327_2e.htm
which could be related to SSC620D series: http://www.datasheet4u.com/download_new.php?id=822986
Offline dav
Reversed a bit the schematic, it's different from all of them.
Here the pinout:
1  Vcc
2  Feedback
3  GND
4  maybe Over Temperature Protection (*)
5  Startup voltage
6  NC
7  Gate Output
8  100R to GND and a capacitor to GND
(*) there is a path to a grey SMD component, with TH2 label, near the switching Mosfet. I measured 560R across it.
It seems there is not a Current Sense function, as the Source is at GND.
« Last Edit: February 25, 2017, 01:22:38 pm by dav »
