Author Topic: Need help Gw instek 1850d psu weird display  (Read 1389 times)
Offline justin55162000
  • Country: hk
« on: February 22, 2017, 10:42:41 am »
I am a newbie of electronic, sorry for my poor knowledge.
I recently pick up a Gw instek gps-1850d psu, but the display read "1." as the photo, when nothing is plugged in.
And when start the machine, it have some noise, I wonder if that's normal.
Is that possible to be fixed?
Offline JFJ
Re: Need help Gw instek 1850d psu weird display
« Reply #1 on: February 22, 2017, 01:29:22 pm »
Might the power supply be in slave mode? For normal operation, the rear panel slider switch should be set in the 'MASTER' position.
  • Country: hk
« Reply #2 on: February 22, 2017, 01:55:18 pm »
Thanks for your reply, but I have doubled check that I have chosen the master mode.
Offline singapol
  • Country: sg
« Reply #3 on: February 25, 2017, 09:50:28 am »
GW Instek service mauals are hard to come by...At leat there is the user manual:
Instruction manual:
http://assets.tequipment.net/assets/1/26/Documents/GPS-Small-series_manual.pdf
Not the actual service manual but at least you can have an idea of how a similar power supply is constructed
with schematics. BTW there is a block diagram of GPS1850D in the user manual which is similar to GPD3303S.
GDP3303 service manual:
http://www.eltest.hu/pdf/GPD3303SM.pdf
Good luck. You need to open up the box to investigate. :)
« Last Edit: February 25, 2017, 09:52:21 am by singapol »
