Author Topic: Need Help idenfiying A Part: XPS 18 No power fault  (Read 603 times)
Offline iamdarkyoshi
« on: October 05, 2017, 08:25:30 pm »
Hello everyone. I've recently obtained an XPS 18 tablet that didn't power on. It tried, but it would instantly shut off. Removing the HDD made it at least spin the fan for half a second. Anyway, I've discovered the fault, and its one of two diodes on what appear to be part of the power input/switching circuitry.
Its the rightmost black square, one side looked a little iffy.
I bypassed it with a very messy soldering job, and the damn machine actually POSTs, so I'm almost certain its the fault.
Now I need to figure out what the heck it is. It must be a diode of some sort, all four pins on each side are commoned together, and in one direction, read a voltage drop of 0.200v and in the other, infinite.
The part reads 1317 with a sideways SIF to the left of it.
I'd love to get this machine working properly, so if you guys could help me find a replacement part, that would be awesome.
Re: Need Help idenfiying A Part: XPS 18 No power fault
« Reply #1 on: October 06, 2017, 02:03:47 am »
Good news and bad news. Good news is that I just ran some bodgewires to a 30v 15A schottkey diode that was too large to surface mount, and it boots fine. However, it rejects all chargers, even though the sense line is not broken anywhere along the line, my dell laptop has no issue with my chargers.
It also rejects the battery, saying the temperature is too high, which is weird, and I have a spare battery, it behaves the same.
