Electronics => Repair => Topic started by: hercegovac on June 08, 2019, 03:18:53 am
need help identifying component labeled 4901 rh45 on AMD RX Vega 56
Going by the Q-labeling and closeness to an inductor, i'm gonna guess that it may be a MOSFET, possibly this one - https://www.onsemi.com/pub/Collateral/NTMFD4901NF-D.PDF (https://www.onsemi.com/pub/Collateral/NTMFD4901NF-D.PDF)
I hoped that was the right part until after I removed it from the PCB, the pinout on the bottom does not matches the spec sheet drawing
Also it is much smaller that typical mosfet used on GPUs
It's just a slightly different footprint of the same type I think. (But I haven't looked over all the specs. )
https://uk.farnell.com/on-semiconductor/ntlld4901nftwg/mosfet-n-ch-30v-9-5a-8wdfn/dp/2216673
(EDIT : the current capacity is smaller)
