Author Topic: need help identifying component labeled 4901 rh45 on AMD RX Vega 56  (Read 230 times)
Offline hercegovac
Online LateLesley
  • Country: scotland
Re: need help identifying component labeled 4901 rh45 on AMD RX Vega 56
« Reply #1 on: June 08, 2019, 11:26:12 am »
Going by the Q-labeling and closeness to an inductor, i'm gonna guess that it may be a MOSFET, possibly this one - https://www.onsemi.com/pub/Collateral/NTMFD4901NF-D.PDF
Offline hercegovac
« Reply #2 on: June 08, 2019, 01:54:20 pm »
I hoped that was the right part until after I removed it from the PCB, the pinout on the bottom does not matches the spec sheet drawing
Offline hercegovac
« Reply #3 on: June 08, 2019, 02:00:27 pm »
Also it is much smaller that typical mosfet used on GPUs
Online LateLesley
  • Country: scotland
« Reply #4 on: June 08, 2019, 03:31:36 pm »
It's just a slightly different footprint of the same type I think. (But I haven't looked over all the specs. )
https://uk.farnell.com/on-semiconductor/ntlld4901nftwg/mosfet-n-ch-30v-9-5a-8wdfn/dp/2216673
(EDIT : the current capacity is smaller)
« Last Edit: June 08, 2019, 03:34:01 pm by LateLesley »
