Hi, i have a Fluke 179 damaged due to battery leaked and cause some damage to the pcb track and missing one or two smd device. Maybe a resistor, jumper or capacitor.
The damage is located below the COM input terminal. Near a SMD transistor. The transistor look intact but with some components destroyed by corrosion. It would be most appreciated if you gurus can help me with this issue, Identification of dmd parts and the midding pcb track.
Attached is the picture i took.
Thanks in advance.
