Author Topic: Need Help - Phillip PM5150 Service Manual  (Read 2622 times)
Offline chihaxinhTopic starter
  • Country: vn
« on: September 15, 2016, 07:14:04 am »
Hi everybody
I have one Signal Generator - Fluke-Phillip PM5150 have signal gain error in output . I need repair but don't have service manual, i searching in internet but not found in time.
Many thank so much !
Best regards
Nam Nguyen Hai
Offline tautech
« Last Edit: September 15, 2016, 09:46:29 am by tautech »
Avid Rabid Hobbyist
Offline oldway
Re: Need Help - Phillip PM5150 Service Manual
« Reply #2 on: September 15, 2016, 11:56:18 am »
The output power amplifier or the step attenuator are probably faulty.
If you don't find the service manual of the PM5150, you could use the service manual of the PM5193.
It is possible that the output power amplifier and the step attenator are the same.
http://isurplus.com.au/manuals/Philips%20PM5193%20Service%20Manual.pdf
Offline enp13
« Reply #3 on: May 24, 2018, 05:08:53 am »
On an unrelated note, have you noticed that it emits a -10V 90ms long pulse from the output connector when you first power it on?  Mine does that.  Very annoying!  Surprised I can't find anything about this bug on the internet.  My firmware version is 1.11
Offline dodge bullets
« Reply #4 on: April 27, 2023, 01:43:30 am »
I have the same ugly negative pulse on startup. You would think they would mute the output while this occurs.
Now that I am aware of this, I will ensure that I am not hooked to anything that can be harmed by this pulse (I have the same firmware version).
I was looking for a new fan, this one is far too noisy.
