Hi. I am new here. Would anyone be able to direct me to a solution for this problem. I have a 30V driver for LED Christmas tree lights. The driver connects to a controller that makes the lights blink in various sequences dependng on which buttons you push.
The connection between the driver and controller was intermittent. I traced the problem to a broken wire on the 29V side of the driver due to over-flexing where the wire on the 29VDC side comes out the 120VAC plug/transformer/driver unit on its way to the controller.
I cut the wires in the 20VDC pair at the break and bared enough conductor to make an effective repair … but I made the mistake of not taking a picture first. Now I do not know which way to connect the dc wires.
How can I determine the correct way to connect the wires so that the light controller and subsequently the lights receive the correct polarity?
Is there a safe way to test before making a final connection?
Is there a risk that connecting the wrong way would destroy the controller?
The driver is Ting Shen Industries Model TS-8W29V rated 120VAC/29VDC at 0.28A.
This connects over a pair of 20 AWG wires, one of which is "striped" with the ratings of the wire and insulation printed on it. Would this striping help identify the required polarity?
I have appended a photo that shows the situation.
Yes, the way to do it is to connect a multimeter set on dc volts at around 30v, to the controller terminals. Switch on and check which way the meter probes produce a positive voltage reading. Usually it is the core that has the stripe on is the positive. Resolder the wires back on and all should be OK. If not, reverse the wires and try again. Most Christmas lights are LEDS so reversing the polarity shouldn't do any harm. They will work one way only.
DON'T DO THAT *YET*! The controller is 'smart', so its not just a simple connection to a string of static LEDs. It looks like that 29V connection to the wallwart is actually a plug, normally held in by the screw on retaining ring still on the wire. If that plug's keyed to only fit one way, the odds of it being reverse polarity protected aren't that good. If however i can fit either way round, you are good to go and splice it as Specmaster suggests.
If the plugs keyed, it a 50:50 gamble you'll get it right the first time. If you loose and connect it backards, there's a significant chance it will have killed it, so if it looks like the controller case can be popped open with the aid of a spudger, or it has hidden screws, it would be worth taking a look inside, as I'd bet we can identify the correct polarity if we can see photos of both sides of the board. Heck, it may even be marked on the board!
If you don't or cant open it, the best chance is if you can see any trace of the writing on the remaining insulation, or if there's a ridge or stripe on the outside of the insulation of one wire (not the traces left in the middle from splitting them). Otherwise, how lucky are you feeling today?
