Ok, so I have made some progress, the resetting with screen flashing was caused by a missing Can bus data line (clip was not making good connection). I have fixed that and now when I send the power up code ID 0x000 data 0x63 0x00 0x00 0x00 0x00 0x00 I now get the illumination for the buttons to glow and the eject button now works. I am still struggling with sending an additional code after this one with the code I have now.
#define DEBUG 0
// RX TX
HardwareSerial Serial3(PA10, PA9);
/* Symbolic names for bit rate of CAN message */
typedef enum {CAN_50KBPS, CAN_100KBPS, CAN_125KBPS, CAN_250KBPS, CAN_500KBPS, CAN_1000KBPS} BITRATE;
/* Symbolic names for formats of CAN message */
typedef enum {STANDARD_FORMAT = 0, EXTENDED_FORMAT} CAN_FORMAT;
/* Symbolic names for type of CAN message */
typedef enum {DATA_FRAME = 0, REMOTE_FRAME} CAN_FRAME;
typedef struct
uint32_t id; /* 29 bit identifier */
uint8_t data[8]; /* Data field */
uint8_t len; /* Length of data field in bytes */
uint8_t ch; /* Object channel(Not use) */
uint8_t format; /* 0 - STANDARD, 1- EXTENDED IDENTIFIER */
uint8_t type; /* 0 - DATA FRAME, 1 - REMOTE FRAME */
} CAN_msg_t;
typedef const struct
uint8_t TS2;
uint8_t TS1;
uint8_t BRP;
} CAN_bit_timing_config_t;
CAN_bit_timing_config_t can_configs[6] = {{2, 13, 45}, {2, 15, 20}, {2, 13, 18}, {2, 13, 9}, {2, 15, 4}, {2, 15, 2}};
* Print registers.
void printRegister(char * buf, uint32_t reg) {
if (DEBUG == 0) return;
Serial3.print(buf);
Serial3.print(reg, HEX);
Serial3.println();
* Initializes the CAN filter registers.
* @preconditions - This register can be written only when the filter initialization mode is set (FINIT=1) in the CAN_FMR register.
* @params: index - Specified filter index. index 27:14 are available in connectivity line devices only.
* @params: scale - Select filter scale.
* 0: Dual 16-bit scale configuration
* 1: Single 32-bit scale configuration
* @params: mode - Select filter mode.
* 0: Two 32-bit registers of filter bank x are in Identifier Mask mode
* 1: Two 32-bit registers of filter bank x are in Identifier List mode
* @params: fifo - Select filter assigned.
* 0: Filter assigned to FIFO 0
* 1: Filter assigned to FIFO 1
* @params: bank1 - Filter bank register 1
* @params: bank2 - Filter bank register 2
void CANSetFilter(uint8_t index, uint8_t scale, uint8_t mode, uint8_t fifo, uint32_t bank1, uint32_t bank2) {
if (index > 27) return;
CAN1->FA1R &= ~(0x1UL<<index); // Deactivate filter
if (scale == 0) {
CAN1->FS1R &= ~(0x1UL<<index); // Set filter to Dual 16-bit scale configuration
} else {
CAN1->FS1R |= (0x1UL<<index); // Set filter to single 32 bit configuration
if (mode == 0) {
CAN1->FM1R &= ~(0x1UL<<index); // Set filter to Mask mode
} else {
CAN1->FM1R |= (0x1UL<<index); // Set filter to List mode
if (fifo == 0) {
CAN1->FFA1R &= ~(0x1UL<<index); // Set filter assigned to FIFO 0
} else {
CAN1->FFA1R |= (0x1UL<<index); // Set filter assigned to FIFO 1
CAN1->sFilterRegister[index].FR1 = bank1; // Set filter bank registers1
CAN1->sFilterRegister[index].FR2 = bank2; // Set filter bank registers2
CAN1->FA1R |= (0x1UL<<index); // Activate filter
* Initializes the CAN controller with specified bit rate.
* @params: bitrate - Specified bitrate. If this value is not one of the defined constants, bit rate will be defaulted to 125KBS
* @params: remap - Select CAN port.
* =0:CAN_RX mapped to PA11, CAN_TX mapped to PA12
* =1:Not used
* =2:CAN_RX mapped to PB8, CAN_TX mapped to PB9 (not available on 36-pin package)
* =3:CAN_RX mapped to PD0, CAN_TX mapped to PD1 (available on 100-pin and 144-pin package)
bool CANInit(BITRATE bitrate, int remap)
// Reference manual
// [url]https://www.st.com/content/ccc/resource/technical/document/reference_manual/59/b9/ba/7f/11/af/43/d5/CD00171190.pdf/files/CD00171190.pdf/jcr:content/translations/en.CD00171190.pdf[/url]
RCC->APB1ENR |= 0x2000000UL; // Enable CAN clock
RCC->APB2ENR |= 0x1UL; // Enable AFIO clock
AFIO->MAPR &= 0xFFFF9FFF; // reset CAN remap
// CAN_RX mapped to PA11, CAN_TX mapped to PA12
if (remap == 0) {
RCC->APB2ENR |= 0x4UL; // Enable GPIOA clock
GPIOA->CRH &= ~(0xFF000UL); // Configure PA12(0b0000) and PA11(0b0000)
// 0b0000
// MODE=00(Input mode)
// CNF=00(Analog mode)
GPIOA->CRH |= 0xB8FFFUL; // Configure PA12(0b1011) and PA11(0b1000)
// 0b1011
// MODE=11(Output mode, max speed 50 MHz)
// CNF=10(Alternate function output Push-pull
// 0b1000
// CNF=10(Input with pull-up / pull-down)
GPIOA->ODR |= 0x1UL << 12; // PA12 Upll-up
if (remap == 2) {
AFIO->MAPR |= 0x00004000; // set CAN remap
// CAN_RX mapped to PB8, CAN_TX mapped to PB9 (not available on 36-pin package)
RCC->APB2ENR |= 0x8UL; // Enable GPIOB clock
GPIOB->CRH &= ~(0xFFUL); // Configure PB9(0b0000) and PB8(0b0000)
// 0b0000
GPIOB->CRH |= 0xB8UL; // Configure PB9(0b1011) and PB8(0b1000)
// 0b1011
// 0b1000
GPIOB->ODR |= 0x1UL << 8; // PB8 Upll-up
if (remap == 3) {
AFIO->MAPR |= 0x00005000; // set CAN remap
// CAN_RX mapped to PD0, CAN_TX mapped to PD1 (available on 100-pin and 144-pin package)
RCC->APB2ENR |= 0x20UL; // Enable GPIOD clock
GPIOD->CRL &= ~(0xFFUL); // Configure PD1(0b0000) and PD0(0b0000)
// 0b0000
GPIOD->CRH |= 0xB8UL; // Configure PD1(0b1011) and PD0(0b1000)
// 0b1000
// 0b1011
GPIOD->ODR |= 0x1UL << 0; // PD0 Upll-up
CAN1->MCR |= 0x1UL; // Require CAN1 to Initialization mode
while (!(CAN1->MSR & 0x1UL)); // Wait for Initialization mode
//CAN1->MCR = 0x51UL; // Hardware initialization(No automatic retransmission)
CAN1->MCR = 0x41UL; // Hardware initialization(With automatic retransmission)
// Set bit rates
CAN1->BTR &= ~(((0x03) << 24) | ((0x07) << 20) | ((0x0F) << 16) | (0x1FF));
CAN1->BTR |= (((can_configs[bitrate].TS2-1) & 0x07) << 20) | (((can_configs[bitrate].TS1-1) & 0x0F) << 16) | ((can_configs[bitrate].BRP-1) & 0x1FF);
// Configure Filters to default values
CAN1->FMR |= 0x1UL; // Set to filter initialization mode
CAN1->FMR &= 0xFFFFC0FF; // Clear CAN2 start bank
// bxCAN has 28 filters.
// These filters are used for both CAN1 and CAN2.
// STM32F103 has only CAN1, so all 28 are used for CAN1
CAN1->FMR |= 0x1C << 8; // Assign all filters to CAN1
// Set fileter 0
// Single 32-bit scale configuration
// Two 32-bit registers of filter bank x are in Identifier Mask mode
// Filter assigned to FIFO 0
// Filter bank register to all 0
CANSetFilter(0, 1, 0, 0, 0x0UL, 0x0UL);
CAN1->FMR &= ~(0x1UL); // Deactivate initialization mode
uint16_t TimeoutMilliseconds = 1000;
bool can1 = false;
CAN1->MCR &= ~(0x1UL); // Require CAN1 to normal mode
// Wait for normal mode
// If the connection is not correct, it will not return to normal mode.
for (uint16_t wait_ack = 0; wait_ack < TimeoutMilliseconds; wait_ack++) {
if ((CAN1->MSR & 0x1UL) == 0) {
can1 = true;
break;
delayMicroseconds(1000);
//Serial3.print("can1=");
//Serial3.println(can1);
if (can1) {
Serial3.println("CAN1 initialize ok");
} else {
Serial3.println("CAN1 initialize fail!!");
return false;
return true;
#define STM32_CAN_TIR_TXRQ (1U << 0U) // Bit 0: Transmit Mailbox Request
#define STM32_CAN_RIR_RTR (1U << 1U) // Bit 1: Remote Transmission Request
#define STM32_CAN_RIR_IDE (1U << 2U) // Bit 2: Identifier Extension
#define STM32_CAN_TIR_RTR (1U << 1U) // Bit 1: Remote Transmission Request
#define STM32_CAN_TIR_IDE (1U << 2U) // Bit 2: Identifier Extension
#define CAN_EXT_ID_MASK 0x1FFFFFFFU
#define CAN_STD_ID_MASK 0x000007FFU
* Decodes CAN messages from the data registers and populates a
* CAN message struct with the data fields.
* @preconditions A valid CAN message is received
* @params CAN_rx_msg - CAN message structure for reception
void CANReceive(CAN_msg_t* CAN_rx_msg)
uint32_t id = CAN1->sFIFOMailBox[0].RIR;
if ((id & STM32_CAN_RIR_IDE) == 0) { // Standard frame format
CAN_rx_msg->format = STANDARD_FORMAT;;
CAN_rx_msg->id = (CAN_STD_ID_MASK & (id >> 21U));
else { // Extended frame format
CAN_rx_msg->format = EXTENDED_FORMAT;;
CAN_rx_msg->id = (CAN_EXT_ID_MASK & (id >> 3U));
if ((id & STM32_CAN_RIR_RTR) == 0) { // Data frame
CAN_rx_msg->type = DATA_FRAME;
else { // Remote frame
CAN_rx_msg->type = REMOTE_FRAME;
CAN_rx_msg->len = (CAN1->sFIFOMailBox[0].RDTR) & 0xFUL;
CAN_rx_msg->data[0] = 0xFFUL & CAN1->sFIFOMailBox[0].RDLR;
CAN_rx_msg->data[1] = 0xFFUL & (CAN1->sFIFOMailBox[0].RDLR >> 8);
CAN_rx_msg->data[2] = 0xFFUL & (CAN1->sFIFOMailBox[0].RDLR >> 16);
CAN_rx_msg->data[3] = 0xFFUL & (CAN1->sFIFOMailBox[0].RDLR >> 24);
CAN_rx_msg->data[4] = 0xFFUL & CAN1->sFIFOMailBox[0].RDHR;
CAN_rx_msg->data[5] = 0xFFUL & (CAN1->sFIFOMailBox[0].RDHR >> 8);
CAN_rx_msg->data[6] = 0xFFUL & (CAN1->sFIFOMailBox[0].RDHR >> 16);
CAN_rx_msg->data[7] = 0xFFUL & (CAN1->sFIFOMailBox[0].RDHR >> 24);
// Release FIFO 0 output mailbox.
// Make the next incoming message available.
CAN1->RF0R |= 0x20UL;
* Encodes CAN messages using the CAN message struct and populates the
* data registers with the sent.
* @params CAN_tx_msg - CAN message structure for transmission
void CANSend(CAN_msg_t* CAN_tx_msg)
volatile int count = 0;
uint32_t out = 0;
if (CAN_tx_msg->format == EXTENDED_FORMAT) { // Extended frame format
out = ((CAN_tx_msg->id & CAN_EXT_ID_MASK) << 3U) | STM32_CAN_TIR_IDE;
else { // Standard frame format
out = ((CAN_tx_msg->id & CAN_STD_ID_MASK) << 21U);
// Remote frame
if (CAN_tx_msg->type == REMOTE_FRAME) {
out |= STM32_CAN_TIR_RTR;
CAN1->sTxMailBox[0].TDTR &= ~(0xF);
CAN1->sTxMailBox[0].TDTR |= CAN_tx_msg->len & 0xFUL;
CAN1->sTxMailBox[0].TDLR = (((uint32_t) CAN_tx_msg->data[3] << 24) |
((uint32_t) CAN_tx_msg->data[2] << 16) |
((uint32_t) CAN_tx_msg->data[1] << 8) |
((uint32_t) CAN_tx_msg->data[0] ));
CAN1->sTxMailBox[0].TDHR = (((uint32_t) CAN_tx_msg->data[7] << 24) |
((uint32_t) CAN_tx_msg->data[6] << 16) |
((uint32_t) CAN_tx_msg->data[5] << 8) |
((uint32_t) CAN_tx_msg->data[4] ));
// Send Go
CAN1->sTxMailBox[0].TIR = out | STM32_CAN_TIR_TXRQ;
// Wait until the mailbox is empty
while(CAN1->sTxMailBox[0].TIR & 0x1UL && count++ < 1000000);
// The mailbox don't becomes empty while loop
if (CAN1->sTxMailBox[0].TIR & 0x1UL) {
Serial3.println("Send Fail");
Serial3.println(CAN1->ESR);
Serial3.println(CAN1->MSR);
Serial3.println(CAN1->TSR);
* Returns whether there are CAN messages available.
* @returns If pending CAN messages are in the CAN controller
uint8_t CANMsgAvail(void)
// Check for pending FIFO 0 messages
return CAN1->RF0R & 0x3UL;
uint8_t counter = 0;
uint8_t counter1 = 0;
uint8_t frameLength = 0;
uint8_t frameLength1 = 0;
unsigned long previousMillis = 0; // stores last time output was updated
unsigned long previousMillis1 = 0;
const long interval = 200; // transmission interval (milliseconds)
const long interval1 = 200;
void setup() {
Serial3.begin(115200);
//bool ret = CANInit(CAN_500KBPS, 0); // CAN_RX mapped to PA11, CAN_TX mapped to PA12
bool ret = CANInit(CAN_125KBPS, 2); // CAN_RX mapped to PB8, CAN_TX mapped to PB9
//bool ret = CANInit(CAN_1000KBPS, 0); // CAN_RX mapped to PA11, CAN_TX mapped to PA12
//bool ret = CANInit(CAN_1000KBPS, 2); // CAN_RX mapped to PB8, CAN_TX mapped to PB9
//bool ret = CANInit(CAN_1000KBPS, 3); // CAN_RX mapped to PD0, CAN_TX mapped to PD1
if (!ret) while(true);
void loop() {
CAN_msg_t CAN_TX_msg1;
CAN_msg_t CAN_RX_msg;
CAN_TX_msg1.data[0] = 0x63;
CAN_TX_msg1.data[1] = 0x00;
CAN_TX_msg1.data[2] = 0x00;
CAN_TX_msg1.data[3] = 0x00;
CAN_TX_msg1.data[4] = 0x00;
CAN_TX_msg1.data[5] = 0x00;
CAN_TX_msg1.len = frameLength1;
unsigned long currentMillis1 = millis();
if (currentMillis1 - previousMillis1 >= interval1) {
previousMillis1 = currentMillis1;
if ( ( counter1 % 2) == 0) {
CAN_TX_msg1.type = DATA_FRAME;
if (CAN_TX_msg1.len == 0) CAN_TX_msg1.type = REMOTE_FRAME;
CAN_TX_msg1.format = STANDARD_FORMAT;
CAN_TX_msg1.id = 0x000;
CANSend(&CAN_TX_msg1);
frameLength1++;
if (frameLength1 == 7) frameLength1 = 0;
counter1++;
CAN_msg_t CAN_TX_msg;
CAN_TX_msg.data[0] = 0xFD;
CAN_TX_msg.data[1] = 0x16;
CAN_TX_msg.data[2] = 0x3F;
CAN_TX_msg.data[3] = 0xFF;
CAN_TX_msg.data[4] = 0xFF;
CAN_TX_msg.data[5] = 0xFF;
CAN_TX_msg.data[6] = 0xFF;
CAN_TX_msg.data[7] = 0xFF;
CAN_TX_msg.len = frameLength;
unsigned long currentMillis = millis();
if (currentMillis - previousMillis >= interval) {
previousMillis = currentMillis;
if ( ( counter % 2) == 0) {
CAN_TX_msg.type = DATA_FRAME;
if (CAN_TX_msg.len == 0) CAN_TX_msg.type = REMOTE_FRAME;
CAN_TX_msg.format = STANDARD_FORMAT;
CAN_TX_msg.id = 0x415;
//CANSend(&CAN_TX_msg);
frameLength++;
if (frameLength == 9) frameLength = 0;
counter++;
if(CANMsgAvail()) {
CANReceive(&CAN_RX_msg);
if (CAN_RX_msg.format == EXTENDED_FORMAT) {
Serial3.print("Extended ID: 0x");
if (CAN_RX_msg.id < 0x10000000) Serial3.print("0");
if (CAN_RX_msg.id < 0x1000000) Serial3.print("00");
if (CAN_RX_msg.id < 0x100000) Serial3.print("000");
if (CAN_RX_msg.id < 0x10000) Serial3.print("0000");
Serial3.print(CAN_RX_msg.id, HEX);
} else {
Serial3.print("Standard ID: 0x");
if (CAN_RX_msg.id < 0x100) Serial3.print("0");
if (CAN_RX_msg.id < 0x10) Serial3.print("00");
Serial3.print(" ");
Serial3.print(" DLC: ");
Serial3.print(CAN_RX_msg.len);
if (CAN_RX_msg.type == DATA_FRAME) {
Serial3.print(" Data: ");
for(int i=0; i<CAN_RX_msg.len; i++) {
Serial3.print("0x");
Serial3.print(CAN_RX_msg.data[i], HEX);
if (i != (CAN_RX_msg.len-1)) Serial3.print(" ");
Serial3.println();
} else {
Serial3.println(" Data: REMOTE REQUEST FRAME");
I can change between sending the power on code and the radio ID code ID 0x415 data 0xFD 0x16 0x3F 0xFF 0xFF 0xFF 0xFF 0xFF by commenting out either the CANSend(&CAN_TX_msg1); or the CANSend(&CAN_TX_msg); lines. I have found that if I first run it with the power on code and then reprogram it with the radio ID code I have been able to get the boot logo to appear when I press the eject button but it then goes away. My issue is getting it to send both codes in sequence with the correct timing between them. If I just send the power on code I can get the eject button to work and the buttons to illuminate but no display and if I just send the radio ID code nothing happens but the current consumption goes to around 2 Amps so it is sort of powered up (around this much current is also drawn with the power up code as well). Got any ideas why I can not get this code to send 2 Can bus codes in sequence? I really suck at programming and am mostly a hardware person.
