Author Topic: Need help ripped capacitors off board while delidding cell cpu on ps3  (Read 1155 times)
Offline Danthegreat356Topic starter
so i was trying to fix my ps3 fat  mobo cok-001  its the caps between the cpu/gpu bus and between the ram and the gpu  its described the the service manual here https://www.manualslib.com/manual/830290/Sony-Playstation-3-Sm-Ps3-0013e-02.html?page=29#manual as the ceramic smd capacitors labeled c1193 c1176 c1186  c1190 the caps in that area that i believe are for bus termination but im not sure i also skinned off the ceramic smd caps comming from the ram going to the gpu the ones labled c1148 and 1150 about all the ones in that row as well isent one pic as an example in the board side a pic please any help would be appriceated thanks i need tha value of those ceramic capacitors  1163330-0* Screenshot_20210131-172204.png (310.4 kB. 720x1280 - viewed 183 times.)" alt="" class="bbc_img" />
Offline aqibi2000
Re: Need help ripped capacitors off board while delidding cell cpu on ps3
« Reply #1 on: February 01, 2021, 04:59:37 pm »
Just remove the old ones from a scrap board
« Last Edit: February 01, 2021, 05:01:17 pm by aqibi2000 »
Tinkerer’
« Reply #2 on: February 01, 2021, 05:14:20 pm »
I dont want to scrap it i just wanna fix it i need to know the cap values for the caps i mentioned on the processor and ram bus
Offline aqibi2000
« Reply #3 on: February 01, 2021, 05:35:28 pm »
What I said was remove the Caps  needed from a scrap ps3 board, and use them.
There was a time where I had 10+
Tinkerer’
« Reply #4 on: February 01, 2021, 05:38:37 pm »
Should all ps3s have the same caps for the bus on a fat vs slim etc i think i have a fat ps3 mobo that is no good i might try that one or buy another one
Offline aqibi2000
« Reply #5 on: February 01, 2021, 07:14:40 pm »
Same cpu gpu
Tinkerer’
