Hi everyone,
I'm rehabbing an old ozone generator. The job is pretty simple: I'm just cleaning built-up grime that's been grounding out most of the current that should be going to the plates, and replacing the corroded nuts/bolts and terminals for the plate contacts. I want to use all stainless hardware to prevent the same corrosion problems moving forward. Finding stainless nuts and bolts was easy enough, but the ring terminals are another story. My usual go-tos (DigiKey, Mouser, Newark) have next to nothing in the way of stainless steel and what they do have must be ordered in giant quantities and/or has a lead time of several months.
Can anyone out there recommend a source of stainless crimp-on ring terminals? I am in the USA. My screws are in the 3mm or #4 size range, so I'm looking for a fairly small ring.
Thanks!
