Author Topic: Need help testing Cosel ZUW25 2415  (Read 385 times)
Offline JJ_023Topic starter
« on: January 19, 2024, 06:11:37 pm »
I took this off a donor board.  I am trying to see if the unit is functional.  I tried giving it power 30V. applied to V+ and V-.
I could not get an output.  I checked for output on V+ V- and combinations thereof with COM.
If you look at the pictures you can see the board is potted.  Does anybody know how to test these for functionality?
I would also be interested in hearing opinions on the module as a power supply to experiment with on operational amplifiers.
Here is the datasheet.
https://en.cosel.co.jp/product/powersupply/ZUW/ZUW25/ZUW252415/
As usual thanks to anybody that decides to participate.
Offline coromonadalix
Re: Need help testing Cosel ZUW25 2415
« Reply #1 on: January 19, 2024, 08:02:10 pm »
have you checked out the instruction manual  pdf,  they are simple to put in use
The following users thanked this post: JJ_023
« Reply #2 on: January 19, 2024, 09:39:46 pm »
I have checked out the instructions.  Apparently either I am incapable of following them or it's broken. lol
All kidding aside I am a little stumped as it seems fairly easy to implement.
Thank you for the response.
