Author Topic: Need help to identify SMD component  (Read 1497 times)
Offline titusdisTopic starter
  • Country: hu
« on: November 23, 2020, 12:43:02 pm »
Hello all!
I am looking for some assistance, identifying an smd component, which gets very hot upon plugging in a
Focusrite 4i4 3gen (USB C) soundcard, which shows no sign of life at all.
The part is a 6 pin SOT23 (?) thingy, with U31 marking on the PCB no idea what it is. Some sort of DC-DC converter? Transistor?
Rail-to-Rail converter?
What i suspect id tha marking says:
AUDK 922
AVDK 922
But no luck on that search. Thanks in advance
Titus
Offline Inari
  • Country: ee
Re: Need help to identify SMD component
« Reply #1 on: November 23, 2020, 02:46:47 pm »
Offline tszaboo
« Reply #2 on: November 23, 2020, 03:59:01 pm »
That is a DC-DC stepdown converter (Kapcsolóüzemű tápegység). There is a testpoint next to it, labeled 3.3V, that must be the output, and there is a tespoint on it, labeled VBUS.
If you cannot find out what it is, just desolder the IC and the inductor, and replace it with any module which could do 2-300mA.
The following users thanked this post: titusdis
Online PA0PBZ
« Reply #3 on: November 23, 2020, 04:23:36 pm »
It looks very much like the Ricoh RP500x series, but it looks like it has the pinout of the DFN series, not the SOT-23-6W  :-//
https://www.mouser.jp/datasheet/2/792/rp500-ea-911465.pdf
Offline fzabkar
« Reply #4 on: November 23, 2020, 06:22:48 pm »
MP2141NGTF, Monolithic Power, 1A, Synchronous, Step-Down Converter with 11μA Quiescent Current, 2.3V - 5.5Vin, 1A, marking AUDx, SOT563:
https://www.monolithicpower.com/en/documentview/productdocument/index/version/2/document_type/Datasheet/lang/en/sku/MP2141N/document_id/997/
This is the resource I used:
http://chip.tomsk.ru/chip/ChipDoc.nsf/vc1?readform&start=19500&view=smd&cat=A&count=500
« Last Edit: November 23, 2020, 06:25:11 pm by fzabkar »
  • Country: hu
« Reply #5 on: November 24, 2020, 01:35:59 pm »
Thank You guys for the identification, it really is an Mp2141 i suspect.
Unfortunately i can't get a hold of this unit, (10-14 weeks to produce 5000 pcs...)
So i am looking for a substitution.
Anyone got an idea?
As far as i see it should make 3.3 V out of 5V 1Amp
SOt 563 (I can manage some wiring, but correct pinout would be superb)
Sincerely: Titus
« Last Edit: November 24, 2020, 02:21:49 pm by titusdis »
  • Country: hu
« Reply #6 on: November 24, 2020, 02:17:27 pm »
To NANDBLog:
Köszönöm a meglátást, azt hiszem azt kell tennem amit irtál, mert az alkatrész nem hozzáférhető,
de furcsa is, hogy alapból ezt 1.8- 1.2 V outputra használják, itt pedig 3.3-hoz (gondolom)
Esetleg tudsz ajánlani valami helyettesitést?
Sajnos a VBUS-t sem tudom mennyi lehet, de sejtésem szerint 5V.
Ha ma sikerül leforrasztani ezt a kis Stepdownt, remélem elindul annyira hogy mérni tudjak.
Üdv szintén kishazánkból:TItusz
P.S: Blog nincs esetleg? megnézném
« Last Edit: November 24, 2020, 02:23:16 pm by titusdis »
Offline m k
« Reply #7 on: November 24, 2020, 04:40:04 pm »
I thought you were also Dutch.
Advance-Aneng-Appa-AVO-Beckman-Danbridge-Data Tech-Fluke-General Radio-H. W. Sullivan-Heathkit-HP-Kaise-Kyoritsu-Leeds & Northrup-Mastech-OR-X-REO-Simpson-Sinclair-Tektronix-Tokyo Rikosha-Topward-Triplett-Tritron-YFE
  • Country: hu
« Reply #8 on: November 24, 2020, 04:44:34 pm »
Nope, i am hungarian.  :)
