Author Topic: Need help to indentify this coax-connector...  (Read 2023 times)
Offline carl_labTopic starter
« on: January 26, 2018, 01:51:01 pm »
Outer diameter of the male connector is 3.0mm:
(sorry for poor image quality...)
Offline David Hess
  • DavidH
Re: Need help to indentify this coax-connector...
« Reply #1 on: January 26, 2018, 03:59:48 pm »
They look like reversed sex Peltola connectors but they are not.
I can see that that is a relatively modern design from the small outline surface mount.  Is it audio or RF?
The following users thanked this post: carl_lab
« Reply #2 on: February 07, 2018, 06:34:03 pm »
It is RF, 10MHz.
(sorry for my late reply...)
Offline Neomys Sapiens
« Reply #3 on: February 08, 2018, 01:29:54 am »
From what I can discern on the photographs, I believe that there is no retaining mechanism. Is that correct?
« Reply #4 on: February 28, 2018, 07:23:45 pm »
You are correct, it is just plugged together.
« Reply #5 on: February 28, 2018, 09:43:16 pm »
Ok, from the picture I assume that the PCB-mounted part has a pin contact, but I cannot make it out really good! Does it intermate with some known series? It looks like the cable-mounted part goes INTO the pcb-mounted part completely. If the PCB jack had a female center contact, it could be a slide-on variant of MCX of 1.0/2.3. But the isolator on the cable-mounted 'plug' says female center contact.
Most closely it resembles the inner parts of a SMB. Without the shell, so to say.
Did you already try the Pasternack Identifier?
What market segment is it?
« Last Edit: February 28, 2018, 09:52:59 pm by Neomys Sapiens »
« Reply #6 on: March 01, 2018, 02:55:58 am »
... from the picture I assume that the PCB-mounted part has a pin contact
-> correct. the center contact at the PCB is male
But the isolator on the cable-mounted 'plug' says female center contact. -> correct
-> I could not find a similar connector using the Pasternack reference
What market segment is it? -> Rubidium GPSDO
« Last Edit: March 01, 2018, 04:22:01 am by carl_lab »
« Reply #7 on: March 29, 2018, 02:30:00 am »
Sorry, I'm officially giving up on this one. Did not find anything.
